Knob lights on 00 civic climate control dont light up anymore..
**** lights on 00 civic climate control dont light up anymore..
I have a 00 hatch and for some reason the 3 ***** on left of the climate control dont light up anymore. They used to light up before and would go out but turn back on when you hit the climate control. Everything else lights up on the climate control except for the 3 adjustable ***** on the left. Could it be a short or something or a blown fuse? What do you guys think the problem is??
Re: **** lights on 00 civic climate control dont light up anymore.. (EJ8VTEC)
why would it be the bulbs? would they of just blown out of no where?? due to a short or something??
Mr. Indecisive
Re: **** lights on 00 civic climate control dont light up anymore.. (EKidd)
possibly.. if thats the case then u would have to check all the connections too.. make sure everything is tight and there are no half way clipped wires.
Actually im sure its a clipped wire.. it wouldnt be the bulbs theres a loose connection somewhere. Maybe when u hit a bump/accel/decel it makes better conn/looses conn.
thanks for the info. But it used to light up when you hit it, now it just doenst light up at all anymore.
Mr. Indecisive
hit it? as in banged into it?
before bumping the thread y dont you go take off your console and try looking for loose wires
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8VTEC »</TD></TR><TR><TD CLASS="quote">hit it? as in banged into it?
before bumping the thread y dont you go take off your console and try looking for loose wires</TD></TR></TABLE>
done it like 50 times
its a loose connection between the circuit board and the bulb bases...might need to just replace the wire and be all set. thats what I had to do with mine.
Re: (Genuine Rolla)
Mine did the same thing. They would go out and then if you hit the dash they would pop back on. I went back there and tightened/cleaned up all the connections and now it works fine.
Midori Green
10-27-2008 07:24 PM
cutelilvi3tboig
11-04-2004 09:25 PM
