just ref'd my b18c1 into my 94 honda civic si. Failed, need help.
i just ref today and failed. the guy told me that the carb # for the skunk2 intake manifold is not right, he says that it's for vtec camshaft. i don't understand. he also told me that my aem cold air intake can't be two piece. well here's the paper that he gave me.
Re: just ref'd my b18c1 into my 94 honda civic si. Failed, need help. (lilo_goki)
What kind of name is Slingerland? Anyways, did you buy the Manifold new or used? Might wanna check with Skunk2 for that.
Re: (prettylew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prettylew »</TD></TR><TR><TD CLASS="quote">wow living in CA sucks *****. glad i dont gotta go thru that ****. id rather walk</TD></TR></TABLE>
lol.. i didnt know they go thru your engine and tell you you cant have this and that
i bought it new(manifold). any help would be appreicate, i knoe i have to change the intake now, i'm gonna use a stock one. about the vacuum hose, i'm gonna use the oil/fuel hose to replace it so that'll be fine. i need help on high hc and what about the skunk2 manifold. anyone pass with that manifold on?
Re: (prettylew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prettylew »</TD></TR><TR><TD CLASS="quote"> id rather walk</TD></TR></TABLE>
i'm sure you wouldn't.
Heres a link that gives info on what parts are legal and there EO numbers.
See if your manifold is listed, double check your EO number againist the one listed
http://www.arb.ca.gov/msprog/a...e.php
Hope this helps, goodluck!
Re: just ref'd my b18c1 into my 94 honda civic si. Failed, need help. (wonder squirrel)
if your intake comes in two pieces and is carb exempt then its legal.
Re: (wonder squirrel)
EO Date: 2/24/2003
Manufacturer Name: Group-A Autosports
Device: Skunk2 Racing Intake Manifold
Device Type: Intake Manifold
Part_Number: Model_Specification: Modification_Allowed: Remarks:
307-05-0270 1994-2001 ACURA INTEGRA GSR INTAKE AIR BYPASS (IAB) NO LONGER USED
307-05-0280 1990-2001 ACURA INTEGRA LS, RS, GS
307-05-0280 1997-2001 HONDA CR-V
307-05-0290 1992-1993 ACURA INTEGRA GSR
307-05-0290 1997-1998 ACURA INTEGRA TYPE-R
307-05-0290 2000-2001 ACURA INTEGRA TYPE-R
307-05-0290 1994-1997 HONDA DEL SOL S
307-05-0290 1999-2000 HONDA CIVIC Si
my part number matches it. it's the same but the guy told me that it's use with vtec camshaft. i don't understand, my motor is a gsr, which uses gsr vtec camshafts right? i also need help on solving the high Hc. will seafoam and oil change plus stock intake help?
actually, my eo# is D-537 and part number is 307-05-0270. on the arb web site above, for the skunk2 manifold, the eo# is D-537-2 but the part number is the same. why is the eo# different. anyone with the skunk2 pro-series intake manifold for gsr has the same eo# as mine or different.
Re: (lilo_goki)
couple of things to check but HC is a product of unburnt something weather it is coolant or fuel. so first try new plugs and wires. then if you can take temps before and after the cat it should be 100 degrees hotter after the cat. if it is like 50 degrees hotter than it is working but not completly so a new cat would deffintly clean up the left over emissions. the intake is not causing the HC to go up. if anything the excesive bore of the manifold would get more air in there causing the O2 numbers to go up or possibly run it just a little bit lean and cause NOX to go up. but try that first. or find a shop to hook you up.
Re: (gsrhatch2356)
i'm not smoggin my car, so a shop can't help me. i'm reffing it. i already install new ngk iriduim plugs. for the intake, i have to change it because the ref guy said it's not legal since it's cut into two pieces, it's an aem cold air intake. he also question me about the intake manifold carb sticker, which on the carb website, the eo# is different from mine, mine is d-537 and on the site it says d-537-2. did skunk2 update or what. that's the only problem i have now. as far as hc goes, i'll try to just seafoam motor, and from the vacum hose from the brake booster, and putting it into the gas. after wards, changing oil and putting on a new oil filter. hopefullie this will work. also would i pass if i still have modified pcv. i remember when i had my b16 with modified pcv, because of the skunk2 manifold, i still pass for visual.
Re: (lilo_goki)
Don't sea foam the car yet, I have seen bad emission result after sea foam(clean out carbon, which cause NOX(not a problem in your case), and carbon buildup can be a seal).
Lower your timing 2 degree below spec, change plugs(you did already). http://www.arb.ca.gov/msprog/a...y.php the link say it's for vtec, either the tech don't know much about Honda, or he's fucing with you, and same to the intake(I have seen 2 piece before)
I would go to another ref station
Re: (EvilPhu)
thanks, that's what i was thinking as well, choosing another ref station. i was thinking, my car's a gsr and it's vtec, why did he even told me it's for vtec camshafts. is he nuts. i'm still having problems with high hc, seafoam will be bad eh, will an oil change help lower the hc then. plus what else will lower the hc, i'm planning on changing the pcv hose as well.
Re: (bobjohnson)
Don't forget cap and rotor. Rotors wear out almost instantly.
High HC means unburned fuel from running rich. So it's most likely ignition related or if your injectors are sticking open which would give you much higher HCs than what you have.
