Just installed Skunk2's....why's mt fron end wayyyy jacked up?
Installing my Skunk2 coilovers on my car, stock shocks. Got that bitch all back together, set all the coilovers to the top, back looks fine (kinda looks low actually) but the fron 2 wheels are jacked WAYY up. i'd say a good 5-7 inches. You push on the front end and it will BARELY go down maybe a centimeter, no movement at all. We can't figure out what went wrong.... btw, came with no instructions. We cut the bumpstops and all that ****. DO we have to do anything to the dust covers? Anyone have any clue what could be wrong....?
also, if anyone knows where i can find instrcutions that would help, or if someone wants to scan them
thanks
thanks
New User
Re: Just installed Skunk2's....why's mt fron end wayyyy jacked up? (DragIIcivic)
Ok there are these black sleeve thing's inbetween the Spring and the strut. Take em out if there still in there!
Re: Just installed Skunk2's....why's mt fron end wayyyy jacked up? (Chip398193)
Installing my Skunk2 coilovers on my car, set all the coilovers to the top, back looks fine (kinda looks low actually) but the fron 2 wheels are jacked WAYY up. i'd say a good 5-7 inches.
Try counting the treads from the bottom to get an even drop. That should help.
[Modified by tiiiteb16, 12:10 AM 10/12/2001]
New User
Even with the skunk2's all the way up, it shouldn't set that high, mine did not when I installed them (all the way up). Is your spring going up into the black rings properly, sometimes they will get hung on the ring, and then pop into place.
I have skunk2's and the instructions book. If you left the dust cover in, you should remove them. The instructions say to leave them out. Hope this helps.
Chip398193
10-12-2001 03:31 PM
