just installed a mech. oil pressure gauge. ? about readings.
Old 04-22-2011, 01:41 PM
DelsolVted's Avatar
Default just installed a mech. oil pressure gauge. ? about readings.
i noticed at ideal warmed up it reads about 20 psi and in D it reads about 17 psi. is this normal or do i need to be concerned? i have 187xxx on the motor. any help would be nice thanks James
Old 04-22-2011, 01:49 PM
EJ8_Man's Avatar
Default Re: just installed a mech. oil pressure gauge. ? about readings.
Where did you install the gauge, and what motor is it, at what RPM are you getting 20 psi?
My B18C likes to be around 60 psi at 3000 rpm
Old 04-22-2011, 01:56 PM
DelsolVted's Avatar
d16z6 and 8 900 rpm at ideal. its installed where the oil pressure switch was and put a brass t block in with the stock oil pressure switch, oil gauge.
Old 04-22-2011, 02:00 PM
The Grumpiest
grumblemarc's Avatar
I don't have an automatic. Mine sits at 25PSI when idling and shoots to about 50PSI @ 3K RPM.
Old 04-22-2011, 02:40 PM
EJ8_Man's Avatar
20 psi is fine at that rpm
Old 04-22-2011, 02:45 PM
DelsolVted's Avatar
70ish around 3000.
kornerk12
12-29-2007 05:42 PM
ham
09-05-2006 08:29 AM
mister2racer
06-03-2004 03:46 PM
civicridah
07-17-2003 12:09 PM
IGGY
11-28-2001 02:14 AM
Quick Reply: just installed a mech. oil pressure gauge. ? about readings.
