Just finished a motor swap, no crank, why is this ecu wire cut and wat do i do?
I bought a 95 hatchback shell, put a 1.6 vtec motor in it w/ the corresponding ECU. Went to start it and nothing, I mean nothing at all, no fuel pump priming, only dash lights coming on including CEL for a quick sec, battery is fully charged.fuses are good.
I then thought maybe it had a kill switch installed. Found a cut wire right where it plugs into the ECU. Did some research and discovered it was the Vtec solenoid wire.
Now 2 questions:
1. Why wont my motor crank/prime, I know the motor/ecu is good as I pulled it myself from a running parts car.
2. Where/how do I rehook up that wire. I can find the other end of the cut wire. first plug 2nd pin on the bottom row.(vtec solenoid)
Now 2 questions:
Re: Just finished a motor swap, no crank, why is this ecu wire cut and wat do i do? (Htamotorsports)
try jumping the starter in the engine bay to see if it cranks
If I jump the starter in the engine bay it cranks, but doesnt start because the fuel pump isnt primed.
and yes I do hear a relay click when i turn the key. Im stumped guys help me out!
