just a couple internals!
EDIT: What Do You All Think Of This Setup?
D16a6 block
Z6 Vtec head
88-89 D16A1 (p29) pistons
ZEX street/strip camshaft
Walbro 255lph fuel pump
-what head gasket should i go with and any other suggestions? this will be a daily driven motor and later will be boosted on a custom turbo setup.
EDIT #2: should i go with an EX tranny? will it fit the D16a6 block?
Modified by Squallie at 8:08 PM 10/9/2005
Modified by Squallie at 8:15 PM 10/9/2005
D16a6 block
Z6 Vtec head
Re: just a couple internals! (Squallie)
i believe they do fit, here is a link for some good oem upgrades for d series
http://www.d-series.org/forums...21761
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Squallie »</TD></TR><TR><TD CLASS="quote">ok thanks man, what head gasket should i use for these two?</TD></TR></TABLE>
well that all depends on how high u want ur compression, someone who has a compression calculator could prolly better answer that, i'm not exactly sure, r u having ur head milled at all?
Re: just a couple internals! (Civicse)
no not at all, the block and head will be completely stripped and cleaned then put back together with out any mill work done at all.
what about some suzuki vitara pistons???? anyody running with these? and are they better than the P29 integra pistons? LMK!
