Johnson's High Compression H22a build thread ::in progress::www.ProvenPowerTampa.com
Old 07-02-2009, 06:15 PM
NeKe1point0's Avatar
Default Johnson's High Compression H22a build thread ::in progress::www.ProvenPowerTampa.com
This is a build we are in the process of finishing for a customer. I will update the thread with newer pics soon. All of this will be going in an EG Civic :D Hopefully we will have some dyno footage this week !
Parts list:
H22a block:
Eagle Forged Rods
Mahle Gold Series pistons 11:5.1
Balanced Crank/Pistons/Rods (1/10th of a gram)
Balance shaft delete
H23 manual tensioner
Vibrant Timing belt tensioner
Honda OEM barrings
ARP hardware
H22a cylinder head:
Proven Power port and polish flow bench tested
5 angle valve job
Brian Crower Black Nitride Valves
Brian Crower Titanium Dual Valve springs/Retaniers
Brian Crower stage 3 cams
Blox 70mm throttle body
Skunk2 IM machined to 70mm
7.5 lb custom built flywheel
Custom Hybrid clutch (1800lb pressure plate)
450cc inj
Walbro 255lph
Proven Power custom built header
Password JDM Intake
o yea, and JDM foglights yo...
Old 07-02-2009, 06:20 PM
I'm not Rick!
rick_rabies's Avatar
Default Re: Johnson's High Compression H22a build thread ::in progress::www.ProvenPowerTampa.
dang...
wait that block has a closed deck..?
Old 07-02-2009, 06:26 PM
iliv2xlr8's Avatar
Sweet build. Interested to see the numbers...:D
Old 07-02-2009, 06:28 PM
Murk 'EM's Avatar
some H22s have closed decks just depends on the year
Old 07-02-2009, 09:40 PM
hoffmanb16's Avatar
Old 07-02-2009, 11:50 PM
MHDesigns's Avatar
Originally Posted by hoffmanb16
LMAO!
Old 07-05-2009, 04:35 PM
Quick update...
Old 07-06-2009, 08:59 AM
Slight hold up...
Old 07-06-2009, 11:14 AM
jr-jdm's Avatar
REALLY NICE SET UP..
Old 08-11-2009, 09:05 AM
#1rudebwoy's Avatar
HEY MAN THESE GUYS ARE DOING MY BUILD ALSO.....LOL A GREAT GROUP OF GUYS AND THEY LOVE WHAT THEY DO. IF ANYONE IS IN THE TAMPA AREA GO THERE AND GET WORK DONE , LOOK OUT FOR A TURBO 2.4L LUDE COMMING VERY SOON.
Old 03-06-2012, 04:25 AM
joelkarlonas's Avatar
what did you guys do as far as machining the block?
Old 03-06-2012, 04:33 AM
jbpnoman's Avatar
You realize you're bumping a 3 year old thread, right?
Since you didn't bother reading the post, flow tested port and polish, 5 angle valve job, BC head hardware.
hondabigblock
12-07-2008 05:41 AM
93h22a1vtec
10-20-2005 04:57 PM
mattmw88
09-08-2002 07:14 PM
Quick Reply: Johnson's High Compression H22a build thread ::in progress::www.ProvenPowerTampa.com
