jdm seats into EK.. what about seatbelt sensor?
ok, i just picked up a set of jdm GSR seats. the seat belt sensor is on the passenger (jdm driver) side.. so is there anyway i can swap it over to the driver side (jdm paseenger) so the seat belt light on my cluster turns off when i put on my seat belts?
Re: jdm seats into EK.. what about seatbelt sensor? (ieatrice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ieatrice »</TD></TR><TR><TD CLASS="quote">wouldn't it be backwards</TD></TR></TABLE>
sure it would, but i dont think it would be a problem if it fit and all.
Re: jdm seats into EK.. what about seatbelt sensor? (john666)
gsr seats don't bolt up into ek's like stock, so i ended up swapping the complete rails over including the seat belts and sensor! woot, problem solved\
RESULT:
RESULT:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ieatrice »</TD></TR><TR><TD CLASS="quote">gsr seats don't bolt up into ek's like stock, so i ended up swapping the complete rails over including the seat belts and sensor! woot, problem solved\
Haha, that's true. I never figured that it was going into your EK. You would have to sway the inners rails anyways.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BALLIN H22 EK »</TD></TR><TR><TD CLASS="quote">just pull the bulb out of the cluster </TD></TR></TABLE>
Or unplug the plug from under the seat. The light won't come on.
Re: jdm seats into EK.. what about seatbelt sensor? (BlueIntegraBoy)
Unbolt it and swap the right to the left...There is a bolt that holds the seat belt locking engagement. becareful when pulling out the sensor wire...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">
Or unplug the plug from under the seat. The light won't come on.</TD></TR></TABLE>
That's the easy way to do it. If you don't plug in the plug then the dash light won't come on at all, even if the seatbelt isn't buckled.
o0ohaviko0o
12-12-2007 08:26 AM
GAME OVER 2007
09-30-2006 10:38 AM
dut
12
02-14-2006 10:50 AM
GetawayInMoscow
01-25-2006 02:19 PM
