jdm ITRR momo SRS steering wheel fit EK?
anyone know if a jdm itr momo with airbag steering wheel fit our ek`s?
here is a pic.
the wheel looks exactly like a ctr wheel.... but i need to know if it will fit.
thanks
here is a pic.
thanks
Re: jdm ITRR momo SRS steering wheel fit EK? (jdmEL)
EDIT woops didnt see it was an ITR...thought it was a CTR so i dont know....
Modified by TheRedSkoolingBus at 9:01 AM 7/27/2003
i dont think it will fit ek.. i have the non-srs, and i believe its the same rack as that one. it should only fit eg & dc
JDM ITR momo won't fit EK, you have to get one from EK9. The hub is different.
ITR momo steering would fit eg or dc.
Guest
Posts: n/a
This is what you need to know. JDM ITR (DC2) MoMo SRS steering wheel will fit EG and of course DC2. I know because I have one in my EG. However, If you want JDM SRS momo wheel to fit in EK you need CTR (EK9)Steering wheel. The difference is the way the 2 large knotches are cut on hub. ITR knotches are horzontal on hub (straight across). CTR knotches are Vertical (straight up and down on hub. This is what you need for EK. They both look identical however the hubs are different. Oh yeah! IF you have cruise control on steering wheel you have to disassemble it. Take the board off the cruise control unit and plug board back into cruise control jack. This is the only way the horn will work. Carefully place board in steering wheel on right side and reassemble airbag unit. Last but not least you may have to use SRS factory jack from EK original wheel. I had to use my EG SRS jack on the ITR SRS momo wheel because they do not match. If you have any problems I have pics. Please unplug SRS fuse and battery cable for 5 minutes. Or so much for $400 steering wheel. POP GOES THE SRS!
Re: jdm ITRR momo SRS steering wheel fit EK? (egnj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egnj »</TD></TR><TR><TD CLASS="quote">the itr steering wheel will fit 94 up tegs and egs</TD></TR></TABLE>
Why not 94 and below? EG6 steering wheels fit on the CRX, and I think
that the CRX and the old Integras are the same. Point being that it could
fit on DA Integras and CRX's also. No?
Re: (jonas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonas »</TD></TR><TR><TD CLASS="quote">it will fit if you can find an EK momo SRS hub.
otherwise.. no.</TD></TR></TABLE>
Sorry to go against the ctr king but Jonas, your wrong. I tried
with that ctr srs hub I have. Didn't have the wheel, but tried with
the hub to see if it would work. The hubs hole is much bigger.
sk8shorty012
06-11-2006 07:59 PM
hatch96back
06-18-2002 03:19 PM
