JDM ITR cluster into 99-00 Civic
jus f0 dekarayshunZ
Now I have searched quite a bit but, to no avail, I am unable to come up with a 100 percent for sure answer. I have looked over the diagrams but no one knows for sure whether or not the USDM ITR diagram is the same as the JDM ITR cluster diagram. So, now I need some help trying to get this bad boy to work. Someone please help.
jus f0 dekarayshunZ
Re: JDM ITR cluster into 99-00 Civic (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi »</TD></TR><TR><TD CLASS="quote">it should be the same because you can put jdm cluster in usdm with no problems except for the airbag wiring</TD></TR></TABLE>yes but i believe you have to switch a few things around. i.e. the green film on the backing, which in turn changes the pin designations que no?
Re: JDM ITR cluster into 99-00 Civic (ciRcuitJerk)
its fairly simple, i have it in my ek. i just wired it like the usdm 99spec one i think and it works fine. i am pretty sure its the 99spec one, but i could be wrong since i did it well over 2yrs ago.
jus f0 dekarayshunZ
Re: JDM ITR cluster into 99-00 Civic (BoostedB20Z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedB20Z »</TD></TR><TR><TD CLASS="quote">its fairly simple, i have it in my ek. i just wired it like the usdm 99spec one i think and it works fine. i am pretty sure its the 99spec one, but i could be wrong since i did it well over 2yrs ago.</TD></TR></TABLE>thanks for nothing
i have a newer itr cluster. 98+ spec and the cluster is going into a 99 honda civic. so can someone post which one i need
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ciRcuitJerk »</TD></TR><TR><TD CLASS="quote">thanks for nothing
jus f0 dekarayshunZ
Re: JDM ITR cluster into 99-00 Civic (BlueIntegraBoy)
yea thats the one that i usedi believe i pmed you the other day blue integra boy. i shall try it with that diagram once again.
