JDM ITR 23mm on EJ1 Coupe
QUESTION: JDM ITR 23mm on EJ1 Coupe
I Plan on purchasing a ITR 23mm rear sway bar for my 95 2-door coupe...is it possible that I can use my stock LCA's? is there n e thing I should know and worry about b4 I purchase the sway bar? installation problems? fitment issues? etc...??? please help...thanxs!!!
go to http://www.beaksproducts.com and buy the EG Install Kit. Cost you about $150 if I remember right. Also...you should get some Integra LCA's rather than modify your stock ones. Another thing...make sure you have either a GSR or ITR Front swap first...otherwise you'll have massive oversteer.
Re: (H23 EG Hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23 EG Hybrid »</TD></TR><TR><TD CLASS="quote">go to http://www.beaksproducts.com and buy the EG Install Kit. Cost you about $150 if I remember right. Also...you should get some Integra LCA's rather than modify your stock ones. Another thing...make sure you have either a GSR or ITR Front swap first...otherwise you'll have massive oversteer.</TD></TR></TABLE>
so since I already have the stock front sway bar already...I will still have major oversteer if I install the ITR rear sway bar
Stock USDM GSR/ITR Front Sway is 24mm
Stock USDM Civic EX/SI front sway is like 18mm if I remember right.
You're talkin about puttin a bar that is about 5mm larger than the front...which is a lot. Get a GSR/ITR Front Sway before you install the rear. Only other option I can suggest if you don't want to do that...sell the JDM ITR Rear...then buy a GSR Rear Sway. If you do this...you shouldn't have to buy the Beaks Kit since the bar is only 13mm.
There is a site that explains all this stuff very well...but I can't find it. I think it's one of the Geocities sites I found that reached their bandwidth limit...so I can't check. It's in one of the threads in the Integra or ITR Forum under a title like..."GSR vs ITR Sway Bar" or something like that. I'll post it if I find it.
Re: (H23 EG Hybrid)
no, should have no problems. the stock ex/si front sway bar is 21mm. it will handle great with the 23mm rear. you might wanna try adding a gsr 24mm front, but that will probably cause more understeer.
New User
Re: ([626] 95-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [626 »</TD></TR><TR><TD CLASS="quote"> 95-EJ1]
no you will not have major oversteer.
Stock USDM Civic EX/SI front sway is like 18mm if I remember right.</TD></TR></TABLE>
you remembered incorrectly. usdm civic (years 96-00) EX sway bar is 22mm and a civic si (year 99-00) are 26mm which i have.
not sure about your 95 civic but i think its a 21mm.
4everjdm
24
11-04-2010 11:33 AM
