JDM Factory Airbox Question
I have a 94 EJ1 with a B16A2 swapped into it, would a factory JDM Airbox directly bolt up? Thanks in advance!
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">just use an airbox from an ex/si and corresponding filter</TD></TR></TABLE>
all you really need to add to that is the stock intake tube off a del sol vtec. they are much wider then the stock ex/si piece
I got the JDM SIR EG6 Airbox and tube. Would this use the same filter as a Delsol? I ask because the part numbers are different for the Delsol and the EM1 Si
the K&n to use is the ex/si filter, I have the same setup
the bottom piece of the ex/si air box is the same as the SIR.
then difference is the top piece of the air box and the tube that goes to the intake (bigger)
hope this helps
hope this helps
1slowcrx
01-25-2008 03:22 PM
oc_civic
03-22-2005 06:39 PM
