itr steering wheel install
I just got a ITR steering wheel, now I need a hub. Do I have to get a ITR hub? Can I get a after market no name quick release one? Or do I have to get the momo one?
moo-chas grassy-***
moo-chas grassy-***
Re: itr steering wheel install (93_pre-lewd)
Your wheel should have a hub. In case that someone unbolted it from the wheel, good luck finding just the hub. A momo hub will not work with it, nor will any aftermarket hubs since the ITR wheel's hub uses 4 hex nut bolts.
I forgot more about hondas then you will ever know....
Location: hop,skip, and a jump from the city,, new friggin york, USA
1 Post
Re: (97dC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97dC4 »</TD></TR><TR><TD CLASS="quote">shoudl the itr wheel have the hub already on it?</TD></TR></TABLE>
a usdm itr will have the hub integrated into the wheel. my guess is he is talking about the jdm itr non-srs wheel.
in that case, if you do not have a hub, a momo one should work since the wheel is a momo. i bought mine directly from a honda dealer in 2000.
Thanks guys, I did the install yesterday, it looks awesome. Not as difficult I thought it was going to be. One thing though, I took off the SRS hub/clip & now the SRS light is on. Was I suppose to leave that clipped in (I didin't think it would fit under the wheel)? Is there anyway of turning it off?
1 Post
Re: (93_pre-lewd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_pre-lewd »</TD></TR><TR><TD CLASS="quote"> now the SRS light is on...Is there anyway of turning it off? </TD></TR></TABLE>
the best way is to remove the cluster, then pull the bulb. simple.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_pre-lewd »</TD></TR><TR><TD CLASS="quote">One more question how do I hook up the horn?</TD></TR></TABLE>
you need to tap into the horn wire in the yellow srs wires, then make a horn contact to touch the steering wheel. if you have ever seen an ef or earlier model non srs car you will understand what i am talking about. if i was able to walk, i would tell you exactly which wire, but i can't get out to my car right now. sorry.
neutron91
09-11-2006 10:50 AM
dutchman5
02-07-2006 08:30 AM
AFTERZERO
05-11-2004 11:28 PM
jonas
02-04-2004 08:17 AM
