ITR Seat Fitment In EG Hatch??
will an itr back seat fit in the eg hatches??
i know the front seats bolt right in.. but im still unsure about the back seat..
I forgot more about hondas then you will ever know....
Location: hop,skip, and a jump from the city,, new friggin york, USA
1 Post
Re: ITR Seat Fitment In EG Hatch?? (gezzuzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz »</TD></TR><TR><TD CLASS="quote">yes</TD></TR></TABLE>
er... no it doesn't. please do not post if you have no clue what you are talking about.
the top cushions will bolt in, but the bottom cushion is a different story. you will need to fabricate brackets for the front mounts, and install a nutsert for the rear mount (as there is no hole for a bolt on the rear mounting tab).
Re: ITR Seat Fitment In EG Hatch?? (Rodney)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rodney »</TD></TR><TR><TD CLASS="quote">
the top cushions will bolt in, but the bottom cushion is a different story. you will need to fabricate brackets for the front mounts, and install a nutsert for the rear mount (as there is no hole for a bolt on the rear mounting tab). </TD></TR></TABLE>
good info...thats exactly what i had to do
thanks for the info.. so no work at all on top top 1/2.. and the bottom just have to fabricate 3 brackets.. can it be done in a day?? :D
1 Post
Re: ITR Seat Fitment In EG Hatch?? (boostedsingle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedsingle »</TD></TR><TR><TD CLASS="quote">thanks for the info.. so no work at all on top top 1/2.. and the bottom just have to fabricate 3 brackets.. can it be done in a day?? :D</TD></TR></TABLE>
you only need to make two "L" shaped brackets for the front of the lower cushion. the top bracket needs a nutsert installed in the sheet metal. if you do not have access to a nutsert tool, you could use a bolt & nut, but i think it would be tough to access behind because the fuel tank is in the way. i did mine in about half an hour, much much less then a day.
I guess ill be nice and post a link on how they fit.
https://honda-tech.com/zerothread?id=1315439
Just been covered 1223986745798632789615521670295 + times here.
Re: ITR Seat Fitment In EG Hatch?? (EgSalad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EgSalad »</TD></TR><TR><TD CLASS="quote">I guess ill be nice and post a link on how they fit.
Just been covered 1223986745798632789615521670295 + times here.</TD></TR></TABLE>
thanks for the link.. seems the 2dr back and 4dr cusion are the way to go..
thanks again for all the help guys.
CivicSiR
10-25-2004 08:25 AM
