ITR rear sway + bsq kit but what rear lower tie bar???
i have itr rear sway bar and BSQ kit that I need to install on my car. My question is what rear lower tie bar will fit with this combo. Currently I have SRR lower tie bar and from I what i've searched, SRR lower tie bar does not fit because the SRR is meant for 19mm but the itr is 22mm and also I would need custom d brackets and bushings. Is this true??? If so, what tie bar should I use. I could get stock ITR or neuspeed, will they fit???
Re: ITR rear sway + bsq kit but what rear lower tie bar??? (eEKEGg)
benen will work with spacers and longer lca bolts.
skunk2 and neuspeed will not work at all.
spoon will work no spacers.
Re: ITR rear sway + bsq kit but what rear lower tie bar??? (Touch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Touch »</TD></TR><TR><TD CLASS="quote">can I get a bump for being ignored...</TD></TR></TABLE>
i didnt see you replied
neuspeed/skunk will work with any stock rear swaybar, it just wont work with the beaks kit.
B18C1_EK
02-28-2002 12:01 PM
