ITR rear sway bar on a 94 Hatchback
I was just wondering how easy or hard it is to install a ITR sway bar on a 94 DX hatchback? Also, what parts would I need to make it fit correctly and a ball-park range of how much everything would cost? Thanks alot
Re: ITR rear sway bar on a 94 Hatchback (OhPhuck)
do a search and look at the archives.. there is plenty of this info around the board.. its not hard to do at all.. you will need a beaks reinforcement kit so it doesnt tear apart the LCA frame mount..
check out http://www.beaksproducts.com/main.html
there is also another kit you can buy online that does the same thing, i just dont have the link for it..
Also, I have an ITR bar with the Beaks kit. After seeing the Ground Control bar, Id be inclined to go with it over the ITR/Beaks solution. Adding the prices, the GC solution probably costs the same, it has all the reenforcement you need *and* it's adjustable.
