ITR Intake Manifold help!! What did I mess up?
Old 06-22-2008, 08:44 AM
I Like Hondas's Avatar
Default ITR Intake Manifold help!! What did I mess up?
So I just bought an ITR intake manifold for my poormans type r swap. This is in my 1993 CX hatch. Before I had an OBD2 Si intake mani. I had never done an intake manifold but it really didn't look hard so I got to work on it. I didn't run into much trouble doing the install but now that everything is bolted up and sensors plugged in I'm having some trouble.
First I started the car and it would maybe stay on for a few seconds then it would just die. After about three tries of that it threw a code 14 (IAC (EACV) - idle air control valve ) I was awesome enough to forget to plug it back in So I plugged it back in and tried again. Now the car starts and stays on but idle is REALLY rough and when you give it any gas idle drops really low then stalls. It also smells exceptionally bad. Like its burning to much fuel or something.
I'm thinking about the only options for this problem would be some vacuum line or a sensor that I messed up somehow. But if anyone has had the same thing happen or perhaps knows which sensor or vacuum line might do this that would be EXTREMELY helpful!
Thanks in advance!
P.S. If my description is too vague or pictures are needed just let me know. I'll post 'em.
Modified by I Like Hondas at 9:49 AM 6/22/2008
Old 06-22-2008, 10:35 AM
Resident Gearhead
BryanM.'s Avatar
Default Re: ITR Intake Manifold help!! What did I mess up? (I Like Hondas)
For the second time today...
Are you sure that the MAP and TPS connectors aren't switched around? That may be the cause.
Old 06-22-2008, 10:40 AM
Default Re: ITR Intake Manifold help!! What did I mess up? (mcvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec &raquo;</TD></TR><TR><TD CLASS="quote">For the second time today...
Are you sure that the MAP and TPS connectors aren't switched around? That may be the cause.</TD></TR></TABLE>LOL! I love how you started that post! It's like teaching a child not to do something really stupid.
Let me go check.
Old 06-22-2008, 10:54 AM
Alright. Well you my friend are awesome! That's all it was! THANK YOU THANK YOU THANK YOU!
Old 06-22-2008, 02:59 PM
Resident Gearhead
BryanM.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Like Hondas &raquo;</TD></TR><TR><TD CLASS="quote">Alright. Well you my friend are awesome! That's all it was! THANK YOU THANK YOU THANK YOU! </TD></TR></TABLE>
You're welcome
Funny how I nailed that one twice in one day
https://honda-tech.com/zerothread?id=2327731
RocHatchDX
24
06-17-2013 12:55 PM
97ej6dx
11-27-2010 08:57 AM
white99CF
07-19-2006 06:00 AM
FrekSdn
08-02-2004 09:48 AM
ImportAuto99
07-15-2003 06:42 PM
Quick Reply: ITR Intake Manifold help!! What did I mess up?
