itr control arms!
itr control arms!
my friend bought some jdm tiens for his 97 coupe, the guy said they could fit his car. He said all we needed was some jdm itr lower control arms, so we bought them, we actaully had a hard time installing them , but when we finally got them installed. they were too short, the wheels tilted inwards (positive camber), the car was not drive able. does anyone know how to fix this? are the control arms the wrong ones? are they too short? do we need to do a rear disc conversion to make it work? somebody help us .
Re: itr control arms! (t0p_sh0tta)
na my friend has the 5 lug conversion done to his 95 eg , and everything bolted up fine. like wha i am thinking that the coupe hub is to short.
Re: (sososlodelsol)
so what do you suggest i should do? if i put gsr rear disc converion, will it work with the jdm itr control arms that i already bought???
it simply will not work...you need to get some "jdm style" control arms for an ek to be able to make the teins work
even if you do put the gsr rear disc conversion on it it will still be 3" farther from the control arm mounting point then it is in a gsr
sorry but your just going to have to find some arms for an ek
Re: itr control arms! (Bignel00)
not sure why everyone is giving answers, you didnt mention which type of tein's you have. cant give correct info if we dont know what we have from the beginning?
but hopefully you have the coilovers that you can move the lower perch up and down (where it mounts to the lca) if you do, great take those off and buy some tein ek ones for what ever model shocks you have.
then instead of messing around with the integra lca's. put your stock ones back on, then just buy new lower tein mounting perches for ek? done.
sell the itr lca's for $80 bucks get some new lower mounting perches for $80. then when you sell the teins you will have both eg (or itr type. not sure which ones you have) and also ek buyers looking at your setup.
whats better than that, more buyers equals quicker sell. and not to mention i am more than sure there is someone out there who has teins and that can use the lower perches you dont need.(your not the first to buy a set of coilovers cheap yet not for your car) sell those aswell and you might make some money on the side aswell.
just call tein and they will give you a price over the phone.
this is the easiest way to fix this problem.
Modified by cxSHOE at 11:53 PM 5/16/2007
Modified by cxSHOE at 11:54 PM 5/16/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bignel00 »</TD></TR><TR><TD CLASS="quote">na my friend has the 5 lug conversion done to his 95 eg , and everything bolted up fine. like wha i am thinking that the coupe hub is to short. </TD></TR></TABLE>
Top Shotta is right, that is why it wont work and you are having problems. You are trying to get it to work on a 6th gen, and it wont. Your friends works on his 95 EG, which is a 5th gen, because the EG shares an almost 100% identical set up (as far as mounting points, etc) as the ITR does. When Honda created the EK, things changed (obviously.) Unless you find some control arms that incorporate the ITR Tiens, and your EK chassis. I dont know much about it, but you might want to check out if a EK CTR rear disc swap might have what you need. Worth checking out at least!
Re: itr control arms! (daluv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daluv »</TD></TR><TR><TD CLASS="quote">
Top Shotta is right, that is why it wont work and you are having problems. You are trying to get it to work on a 6th gen, and it wont. Your friends works on his 95 EG, which is a 5th gen, because the EG shares an almost 100% identical set up (as far as mounting points, etc) as the ITR does. When Honda created the EK, things changed (obviously.) Unless you find some control arms that incorporate the ITR Tiens, and your EK chassis. I dont know much about it, but you might want to check out if a EK CTR rear disc swap might have what you need. Worth checking out at least!</TD></TR></TABLE>
no need for all this work... just buy lower perches for ek from tein???? and sell the extra parts left over
if the teins have a lower removable adjustable perches, get in contact with tein and order a set for the ek that looks like a fork like cxSHOE mention.
if the teins dont have the lower removable perch, the only other way is to find a set of CTR rear lower control arms but good luck on that one.
Re: itr control arms! (cxSHOE)
he has the tein hr suspension. i dont know if its removable tho. i have to look at it when i get home. the function 7 lcas are very expensive
Re: (2coupes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2coupes »</TD></TR><TR><TD CLASS="quote">just buy these, it'll solve all your problems
http://cgi.ebay.com/NEW-Functi...wItem</TD></TR></TABLE>
x2.
x2.
HT White Ops
Re: (Bignel00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bignel00 »</TD></TR><TR><TD CLASS="quote">do you guys know if a company makes any cheaper ones than the functions. maybe omni or skunk2?</TD></TR></TABLE>
F7 is the only company that makes ITR-style shocks for 96-00 civics.
Re: (2coupes)
Thats good to know, I wasnt sure when I left my advice earlier! A control arm that incorporates the EK chassis and the ITR struts! Awesome! Dont be cheap about it man, get these function 7's!
Re: (t0p_sh0tta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta »</TD></TR><TR><TD CLASS="quote">What's the advantage to running the ITRs?</TD></TR></TABLE>
using coilovers that he already has instead of having to sell and get different ones, also ITR coilovers usually have more aggressive springrates than standard civic ones
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">if you can find a set, CTR rear LCAs would work also.</TD></TR></TABLE>
not true, CTR and US 6th gen lca's are the same
Re: (2coupes)
hey 2scoops (j/k)
i think this is a terrible way. why spend over 2 bills when he could easily only spend $80 bucks on ek lower perches from tein?
my edit is down below...
hey 2scoops (j/k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bignel00 »</TD></TR><TR><TD CLASS="quote">he has the tein hr suspension. i dont know if its removable tho. i have to look at it when i get home. the function 7 lcas are very expensive</TD></TR></TABLE>
yea those do not have the removable lower perches, so nevermind what i was saying.
