Invidia CF Hood Fitment Problems HELP!!!
So i just purchased this invida hood for my eg hatch, it is brand new. Well i put it on... and then i noticed the fitment was HORRIBLE, well driver side fits fairly nicely, but the passenger side has a 1+ inch gap around the head light and upper part of the fender, i am in shock and pretty pissed. What can i do about this? I checked hood clearance, nothing seemed like it was hitting. It seems as if the hoods frame was molded lopsided.
DRIVER SIDE, HOOD FITS NICE.
PASSENGER SIDE, 1+ INCH GAP AROUND HEADLIGHT & LOWER PART OF FENDER
Modified by Made In OC at 12:19 AM 4/23/2007
* B A N N E D *
Re: Invidia CF Hood Fitment Problems HELP!!! (Made In OC)
wow thats like an inch off all the way around, do you have a sedan by any chance and migh of bought a coupe/hatch hood?
also maybe try rehanging and adusting the hood and fenders? i had to do that to mine to where i had to adujust everything i still have a bow in the middle tho
Re: Invidia CF Hood Fitment Problems HELP!!! (spork motorsports)
i have a hb. What should i do to readjust the hood and fenders?
* B A N N E D *
see how when you remove the fneders there is play in ALL directions for the bolt holes?
just loosen the bolts and move them to where you want them, same with the hood but on a smaller scale, also get hood pins if needed to hold the hood in place, as statted abouve
iv done hoodpins before on my vis hood, and pressed the hood down and it fit reasonably. I dont want to go back to that path. The VIS hood still fit a lot better then this without the hoodpins.
Not really much we can do, if you've got everything adjusted correctly then you just bought a **** hood, call the manufacturer
yup yup sounds like ur goin to have to adjust ur fenders i bought a carbon fiber hood and i had to do the same thing but dnt worry once u do that it should fit better
Re: Invidia CF Hood Fitment Problems HELP!!! (DuN DeALs FiNEsT)
my oem hood is warped like that on the drivers side. not as bad. (i think its from years of hood prop use)
anyways. i played around with those rubber adjusters and the hood latch itself.
i got mine tolerable that way.
now, mine is OEM and not CF, but there is a possibility you can get that thing looking a little better.
take the rubber lifters out of the radiator head light support area. This might let the hood go down just a ****.
you can see it peaking up. in your picture
Re: (dem0nk1d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d »</TD></TR><TR><TD CLASS="quote">take the rubber lifters out of the radiator head light support area. This might let the hood go down just a ****.
those rubber lifter on the passenger side isnt even touching the hood at all. Its like the hood is warped and lopsided. The rubber things are like 1 inch away...
Re: (rleonekc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rleonekc »</TD></TR><TR><TD CLASS="quote">it looks like you mighta got the wrong hood, it may have been the company you bought it froms fault </TD></TR></TABLE>
but the driver side fits fine. Whats the difference from the 4 door and 2dr/hb hoods? longer higher?
Re: (envee)
nothing is different about the coupes/hatches/sedans on civics. everything is the same...it is just the hood...that is what happens when you buy cheaper carbon fiber products...you know...you get what you pay for...but yea, carbon fibre is never perfect...oem is better! don't really need them carbon fibre stuff anyways...return it for your money back...
Re: (ek4_b16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4_b16a »</TD></TR><TR><TD CLASS="quote">nothing is different about the coupes/hatches/sedans on civics. everything is the same...it is just the hood...that is what happens when you buy cheaper carbon fiber products...you know...you get what you pay for...but yea, carbon fibre is never perfect...oem is better! don't really need them carbon fibre stuff anyways...return it for your money back...</TD></TR></TABLE>
ding ding ding
ding ding ding
Re: (Made In OC)
I just bought a Seibon brand one for an EG hatch....fits like a glove....
$380.....picked up......not bad at http://www.weaksauce.org.....
good luck on yours.
good luck on yours.
Re: (og asr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by og asr »</TD></TR><TR><TD CLASS="quote">I just bought a Seibon brand one for an EG hatch....fits like a glove....
good luck on yours.</TD></TR></TABLE>
thanx for the info.
thanx for the info.
Re: (Made In OC)
i had a invidia carbon hood on my hatch and it looked exactly the same. The passenger side lifted up a little and it looked like ****. The best thing i can tell you is contact the manufacturer and let them know. They should send you another one. I sold the car so its now the next owners problem.
