intermittent wipers not working - checked and searched - what am i missing
97 civic
intermittent wipers stopped working, so i took the switch out and cleaned the terminals which weren't dirty. i know there is no relay for this function, so what am i missing? switch bad or something i am overlooking. any help appreciated. really annoying with the rain now.
Re: intermittent wipers not working - checked and searched - what am i missing (hb_guy)
does the other 2 settings work? if so does the wipers go back to their resting place?
Re: intermittent wipers not working - checked and searched - what am i missing (BigRonDawg)
yes, everything else works fine, just the intermittent setting stopped working
Re: intermittent wipers not working - checked and searched - what am i missing (Freemantle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Freemantle »</TD></TR><TR><TD CLASS="quote">Is your ABS working?</TD></TR></TABLE>
don't have abs om a 97 civic dx and there is a relay but not one alone for the intermittent wipers. everything works but the intermittent part
do you happen to have a helms manual? look at page 23-215
it shows a circuit diagram with an integrated control unit (has built in intermittent wiper relay circuit)
to see if your wiper switch has crapped out, check for continuity for the intermittent swithc position, between terminals 1 and 7, and 3 and 4. i can't really explain it well.
Re: intermittent wipers not working - checked and searched - what am i missing (tominos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tominos »</TD></TR><TR><TD CLASS="quote">do you happen to have a helms manual? look at page 23-215
to see if your wiper switch has crapped out, check for continuity for the intermittent swithc position, between terminals 1 and 7, and 3 and 4. i can't really explain it well. </TD></TR></TABLE>
no i got it, thanks for the info, no helms, but i have a haynes - didnt help much
could this be a fuse issue? I'm having the same problem all of a sudden this morning as well. I've also lost my dome lights and my intrument panel wont turn off the door ajar and trunk ajar light, trunk light, Be-be-be-beep sound you car makes when the keys in the ignition is gone too... I'm thinking they all have to be related....
Modified by .y2a. at 6:24 PM 1/2/2006
edit... got it figured out by swapping the 7.5A fuse under the dash....
Modified by .y2a. at 8:08 PM 1/2/2006
matt87
11-22-2005 03:00 PM
