Interior door handle doesn't close properly and the lock barely works (SOLVED)
Old 07-20-2017, 07:36 PM
MikhailM's Avatar
Icon5 Interior door handle doesn't close properly and the lock barely works (SOLVED)
Hi all,
It's been getting progressively worse to the point now when I can barely open my door. I've seen a few videos on fixing the door lock but none seem to mention the problem with the interior handle not going into its position. One video suggests that a spring might be broken or missing, and another that a piece of metal might have broken off and needs to be welded back. It would be nice to know what it might be before taking the door apart. Any ideas?
Thanks.
Old 07-21-2017, 07:33 AM
StayKrafty's Avatar
Default re: Interior door handle doesn't close properly and the lock barely works (SOLVED)
What car?
Old 07-21-2017, 08:23 AM
MikhailM's Avatar
Originally Posted by Stillare
What car?
2000 Civic Si (Canadian version)
Old 07-21-2017, 02:44 PM
Hysterically Calm
TomCat39's Avatar
Pull the door card off and begin inspecting. There is many parts and things that could cause this. All of them will be easily identifiable with a visual inspection. Of which can only be done properly after you pull the door card off.
Old 07-21-2017, 06:03 PM
MikhailM's Avatar
Well, I have fixed it. It turned out that the lever on the lock, which is linked to the interior handle, rusted so badly that it couldn't swivel at all. The solution was simply plenty of WD-40.
Old 07-23-2017, 02:55 PM
civic402lx's Avatar
Default Re: Interior door handle doesn't close properly and the lock barely works (SOLVED)
At least it was an easy fix.
Old 07-23-2017, 05:21 PM
fragmare's Avatar
See what you found taking that door panel off? Curiosity might have killed the cat, but it also fixed the car.
jus455
03-07-2015 08:21 PM
LilTheo
11-04-2010 12:30 PM
braass91
01-04-2008 09:08 AM
SlitUrNek
08-31-2005 06:49 PM
benSC
16
06-10-2004 07:43 PM
Quick Reply: Interior door handle doesn't close properly and the lock barely works (SOLVED)
