integra rear caliper problem
i have an issue wen i was doin my rear brake conversion i was puttin the passenger caliper but i cant get the piston to get in i used the c clamp u guys think i need a new caliper??
Re: integra rear caliper problem
The rear calipers should turn in, not compress. There is a tool that you can rent at Advance to turn them in. It still won't turn, then it is seized and you will need to replace or rebuild the caliper.
x2!!! I used a flat head screw driver to turn mines, it might work for you.
It is seized. You may be able to rebuild it but calipers can be tricky and sometimes too far gone.
www.rockauto.com
These guys have great prices. I would look for a reman.
www.rockauto.com
octaneaccord02
05-31-2008 11:41 AM
Si_Allen
01-10-2007 02:07 PM
