Integra caliper???
Holy ****...thank you for saying "integra calipers" instead of "gsr"!
Yes, integra calipers will bolt onto the ex/si knuckle. You will probably want to upgrade from the 7/8" MC that you have to the integra/civic abs 15/16 unit (or 1" if you can find it...but its not required for this swap).
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">Holy ****...thank you for saying "integra calipers" instead of "gsr"!</TD></TR></TABLE>
Re: (pdiggitydogg)
Yes, integra calipers will bolt onto the ex/si knuckle. You will probably want to upgrade from the 7/8" MC that you have to the integra/civic abs 15/16 unit (or 1" if you can find it...but its not required for this swap).</TD></TR></TABLE>
are you running a rear disc brakes on your ej8? if you are and havent upgraded to at least a 40/40 prop vavle then i wouldn't bolt up the teg calipers. When i did my rear disc conversion on my ej8, i threw on the the front gsr calipers at the same time and braking sucked. I locked up my brake constantly...
If your still running your drums in the rear throwing on the teg calipers shouldn't be a problem at all
Re: (bmoua)
not yet...i have the integra rear disc sittin in the garage...i dont ;look forward to puttin them on right now...i still have to get the brake lines and the ebrake cables...thanks for the information
MotorMouth
04-04-2006 10:16 PM
xtrafastcivic
01-30-2006 06:13 PM
