Instruction on replacing a motor mount?
TSPeed Factory
Re: Instruction on replacing a motor mount? (jdmjay04)
ok, well you want to atleast support the motor with a hydraulic jack. and then just unbolt the two 14 mm bolts that hold the rubber mount to the frame. then you unbolt the 17 mm bolt that goes through the rubber mount. and do the reverse to put back on the new mount.
TSPeed Factory
yeah, don't pay the honda dealership to do it for you. it's very easy and theres only like 3 bolts. those bolts might be hard to take off so a good breaker bar would provide some good leverage.
Re: Instruction on replacing a motor mount? (EKautox)
use your sissor jack in ur trunk thats what i did but make sure you use a piece of wood unless u want to dent ur oil pan
