Installing tie bar onto EG...will it damage the sub frame?
Hey guys I remember reading in the past where people would install aftermarket sway bars without reinforcement and it would rip the sub frame where the LCA bolts onto
would installing a tie bar onto my coupe hurt it at all? I wouldn't want to risk tearing the sub frame
thanks
thanks
Re: Installing tie bar onto EG...will it damage the sub frame? (fasthatchb18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fasthatchb18c1 »</TD></TR><TR><TD CLASS="quote">no, it will not</TD></TR></TABLE>
Thanks...I was thinking it wouldn't but wanted to double check
Re: (H.crx-si)
i ran two setups with rear sway and tie bar combination(on my old 95si):
setup 1
suspension techniques rear sway(19mm) with jic-magic rear lower tie bar. the tie bar bolts on perfect with this setup.
setup 2
jdm itr rear sway bar(23mm) with beaks rear subframe reinforcement kit in addition i also used a beaks rear lower tie bar.
<U>the jic-magic rear lower tie had fitment issues with the beaks reinforcement kit.</U>
setup 1
setup 2
Re: Installing tie bar onto EG...will it damage the sub frame? (Mr.RHTuner)
Ive never heard or seen that happen.. ive had some cheap ones on my car for almost 4yrs and its fine...
Rodzknight
11-18-2006 05:08 PM
slocrxsi
09-05-2003 02:03 PM
