Injen or AEM short ram intake for my del Sol?
hey guys- quick question. should i get an Injen short ram intake for my 1994 Honda del sol with SOHC VTEC engine? or the AEM short ran intake? i can get either one for about $125. (i'm not going to get a Cold Air Intake because there's been way too much flooding when rain comes in my neighborhood and the snow in the Chicago area gets pretty bad)
Re: Injen or AEM short ram intake for my del Sol? (ckdelsol)
your not going to get any noticeable house power difference with the aem over the injen,both intake are pretty much the same, between the 2 i would just go with which ever one you think looks better.
if your worried about getting water in your engine, then get a bypass valve
your not going to notice any power difference with a short ram. It's just suckin' the hot air from the engine bay.
later,
aj
later,
aj
D Tranny Guru
Well if you want the Short intake, don't waste your money and keep the stock setup.
Only 2-3 choices,
AEM or Injun LONG tube or the Slatertake.
[Modified by Mista Bone, 2:30 AM 12/29/2001]
Only 2-3 choices,
Guest
Posts: n/a
Re: Injen or AEM short ram intake for my del Sol? (Mista Bone)
Only 2-3 choices,
Only 2-3 choices,
i just got my AEM cold air for my Civic coupe and i love the thing to death.....would recommend this to anyone.....it rained the day after i intalled it, so i pulled my wheel well back again and there was not even a drop of water in where the filter was
the AEM is a 2 1/5 tubing ..the injen a 3 inch. tube...i chose the AEM cuz the mounting bracket makes for a real clean install..and the narrower tubing of the AEM vs. t he 3inch weapon s actually show d an improved power increase...u tell me
Re: Injen or AEM short ram intake for my del Sol? (KAMiN)
if you go with a 2.5" tubing you are going to have faster air flow to the throttle body. with a 3" the air will get to spred out and then will slow down. You are better off getting an AEM CAI...., another 2.5" CAI, OR bending your self your own intake out of 2.5" tubing
New User
Don't bother with "filter on a stick" with your setup. Get a CAI, AEM w/bypass is best choice if you've got flooding in your area.
HT White Ops
HT White Ops
Re: Injen or AEM short ram intake for my del Sol? (ajn)
Short rams do NOTHING for performance, but are the best LOOKING setup appearance-wise. It's a trade-off for tuners, as always; looks or performance.
Secondly, AEM bypass valves do NOTHING BENEFICIAL unless they are completely SUBMERGED. I don't know how many ppl drive their CiViC in water up to their headlights, but for everyone else all the bypass valve does is disturb the air flow.
HT White Ops
Re: Injen or AEM short ram intake for my del Sol? (fifthgearonline)
if you go with a 2.5" tubing you are going to have faster air flow to the throttle body. with a 3" the air will get to spred out and then will slow down...
HT White Ops
Re: Injen or AEM short ram intake for my del Sol? (BlackDeuceCoupe)
Source: AEM Web Site
<u>Air Bypass Valve</u>
AEM’s Air Bypass valve for Cold Air Induction Systems virtually eliminates the unlikely chance of water ingestion should the filter element become wet from deep puddles, rain, hail, sleet or snow–or any other scenario in which the filter element could encounter [bullsh!t hype - bdc] or become <u>submerged in water</u> [read their lips! - bdc]. The valve installs along the upper portion of the inlet pipe on the same axis as the throttle body centerline. Should a drop in pressure occur within the pipe due to <u>filter submersion</u>, the valve shuts down induction at the filter and routes incoming air through its external orifices, eliminating any chance of water ingestion.
AEM’s Air Bypass Valve is for use on AEM Cold Air Systems only.
The mags test these cheap plastic valves by dropping the air filter into a fish tank full of water at 5000 RPM. The water is sucked about half way up the tube, then the bypass filter opens. Question: What happens to the water in the intake tube when the 'photo op' is done??? This is as bad as those fuc*ing Dura-Lube commercials, as far as I'm concerned.
Anyway, it's your life. Personally, I use the OE airbox with a K&N panel filter. I think Honda engineers are smarter than ppl realize. They did a nice job of designing a filter system that flows nicely, quiets the sound and keeps the water out. That's the route I would suggest you go.
If you want the most performance and configurability, go with the Iceman. If you want to join the AEM groupies, have at it...
HT White Ops
One last point. I've done this AEM vs. Iceman thing before...
Yes, the Iceman comes with a 3-inch K&N Cone filter, however, Knight Engineering usually puts either blue or gold oil on them instead of the red pictured here. AEM use a much smaller 2 1/2 version.
Heres one more idea...
AEM short ram, dont take that one...
I would take the Injen Intake --> Why you ask - well because you can convert this to a CAI with the help of a cold air extension....
Or try the DAC (DC sports intake), its a short ram but you can buy a cold air extension for that as well...
That would be more suited to what you want
ENJOY!!!
ENJOY!!!
HT White Ops
Re: Injen or AEM short ram intake for my del Sol? (B18C-EJ1)
You are correct on some points, but others are complete wrong.
Guest
Posts: n/a
The Iceman air tube starts at 3-inches by the filter and gradually tapers to 2 1/2 at the TB. This increases BOTH volume and velocity. AEM CANNOT COMPARE to Iceman in this regard - period!
What AEM does have over Iceman units is the aluminum intake. When air passes through the tube, it gets cooled instantly. The coated aluminum acts like a heat exchanger.
We've done temp tests on a working AEM, and you'd be supprisied how cold the tube gets at full throttle. The Iceman remains at the same temp, or gets warmer because plastic doesn't disapate heat as well as aluminum.
Personally I use a stock airbox and a drop in filter. I don't care much for flashy stuff like CAI's etc....
Pick what you want because you like it, not because someone told you that it was better or worse.
There are always 2 sides to every story. If it works for you, have fun with it.
HT White Ops
There are some AEM units that are 3" in diameter.
Add their BV and the situation becomes moot anyway. It's like putting a stop sign in the middle of a freeway. Increased velocity means increased HP and Iceman makes them both in spades; AEM doesn't...
What does that have to do with anything? The 3" cone filter iceman uses actually has less surface area in which to draw air from. Also, AEM doesn't use just a 2.5", they also have a 2.75" and a 3" version. It all depends on which intake you purchase.[/i]
Incorrect. Short rams do provide additional performance over stock. In fact, they can provide more overall HP and torque over a CAI. There are cases which engines have put more HP to the ground with a short ram over a CAI.
So, was there anything else I was "complete wrong" about???
[Modified by BlackDeuceCoupe, 10:41 PM 12/30/2001]
New User
Yes the AEM will outpower the short-ram on most cases, but some guys with heavily modded cars with high lift cams (i.e Toda Spec B's), prefer to use short ram for more top end over the AEM. But a CAI is still the best overall choice, but also depends on your setup and if you mainly drag or road race.
