info need on EG
info need on EG
does EG (92 civic HB cx) come with any front or rear sway bar?
if I am getting a ITR rear sway bar(with lca), I wonder if I should do anything to the front? I mean if strong front sway bar is gonna causes more under steer, I dont think I would want that...
someone can also give me info on their setup on EGs? thanks
[Modified by chusai, 11:01 AM 10/26/2002]
Re: info need on EG (chusai)
-Nick-
Former Moderator
If you're going to try and use the ITR rear LCAs then you'll also need to buy rear struts for an ITR as well.
Here's what I did on my own car:
Buy Integra GS-R rear LCAs and then use either the GS-R 14mm bar (what I have since my spring rates are 425F 550R) or the ITR 22mm rear bar.
Don't go too big up front with the bar because then you might actually understeer more than before - I would not go anything over the stock 1992-1995 Si/EX front bar. You'll also need the front LCAs from any 1992-1995 Si/EX or any 1994-up Integra.
EX was only in 4-door in 1992 but they had front and surprisingly rear swaybars too - Si hatch and EX coupe only had front bar.
Does that help any?
Cliffnotes: Use the ITR rear LCAs and you must also use ITR rear struts or aftermarket struts for the ITR - two totally different LCA and strut set-ups.
Does that help any?
I believe that some EG's DO come with front sways, but I don't know about rears.
An EH3 (i.e. 92-95 SI hatchback) also comes with a front sway (21 mm)
An EH2 (i.e. 92-95 CX or DX hatchback) does NOT come with any sway bars.
So, to answer your question: Some EG's come with swaybars
Your car is not an EG, and your car does not come with a swaybar.
Shawn
[Modified by shawnhayes, 3:36 AM 10/27/2002]
Re: info need on EG (B18C5-EH2)
Yeah what he said, the only usdm EGs are del sols
There's also EG 4-doors in the U.S too.
True.
Shawn
dj theoretic
Suspension & Brakes
12-17-2008 05:35 AM
Nothing.Special
03-21-2004 10:49 PM
