Indetify This Sensor.
The thermo is on the inside of that piece? I'm looking for whatever goes inside what I circled and it has a sensor that connects to it.
I thought the thermostat sensor was under the dizzy?
Correct, your ThermoSTAT is located inside that housing. Where you have circled is where your ThermoSWITCH would go and would connect to your plug (from your harness).
the thing under the distributor is the coolant temp sender that sends a signal to your water temp gauge. The sensor in the housing you are asking about is the temp switch that activates the radiator fan.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lollypopking »</TD></TR><TR><TD CLASS="quote">the thing under the distributor is the coolant temp sender that sends a signal to your water temp gauge. The sensor in the housing you are asking about is the temp switch that activates the radiator fan. </TD></TR></TABLE>
aka Thermoswitch.
I tried looking on SLhondaparts.com and for the life of me could not find the part number. I just replaced mine a while ago and thought I kept the bag... Ill look for my receipts
aka Thermoswitch.
aka Thermoswitch.
Edit: FOUND IT!! 37760-P00-004 Its under , Engine/Sub Cord Clamp
aka Thermoswitch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Simmerman »</TD></TR><TR><TD CLASS="quote">Thanks man.
NP, that was for the 92-95, but you can check the 96-00 also. From what I have been told its all the same number
GL
</TD></TR></TABLE>NP, that was for the 92-95, but you can check the 96-00 also. From what I have been told its all the same number
GL
that is the sensor that shows coolant temp to the cu AND THE ECU TURNS the fan on ...
the small plug under the dizzy is for your guage cluster and does nothing but send signals to the cluster.. trust me i know i did a rhd swap and had to wire all the guages sensors to the ecu since the harness was a big pos
