ignition is making clicking noise, car starts sporadically
(HELP) car starts sporadically(not usual, advise wanted)
my car starts for the most part. this isn't a usual starter problem. my car starts for the most part. could the battery be old. this has been going on for a month now. i have to turn the key a couple of time until the car starts sometimes. right now it won't start now
Modified by eternaljihad at 1:06 PM 7/9/2004
Modified by eternaljihad at 1:07 PM 7/9/2004
Re: (HELP) car starts sporadically(not usual, advise wanted) (eternaljihad)
Explain it a bit better. are you saying that sometimes when you start it, it will just click real fast. THen after a couple of tries, it will start?????????
fs
fs
Re: (HELP) car starts sporadically(not usual, advise wanted) (filthy_shovel)
yeah what happens, at first i would have to try once or twice to start the car. if i cut the car off when i go to class when i come back it might take a couple of tries to start the car. there is a click, everything comes on but the car. if i'm lucky on the second or third or fourth try the car will start. but if i mess with the battery wires the car cuts on most of the time, it just now stopped.
Is there any build up on the battery terminals? Blue or green fur, corrosion, or a loose rusty connection? You could get a battery test done at autozone i think for free. Worst case secnario it is your starter or alternator. It just sounds like a battery problem to me though.
Re: (HELP) car starts sporadically(not usual, advise wanted) (civic-si-2000)
i sure hope that it's just the battery. there is a sort of green looking powdery whatever the hell type of stuff around the + - chargers. i have an alarm and i runs like crazy, sometimes i leave the lights on for a whole minute. the same battery has been on the car since i've had it(a year and a half). how did you get Street fighter alpha ken on your picture thing.
clean your battery terminal with baking soda mix with water. then tighten the terminals, besure that when you try to move it to see if it loose. check all the grounds point for loose connection. now try to start the car and see what happen.
Re: (HELP) car starts sporadically(not usual, advise wanted) (2lua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua »</TD></TR><TR><TD CLASS="quote"> check all the grounds point for loose connection. </TD></TR></TABLE>
the grounds where?
do i clean with a toothpick preferably.
sounds good though
the grounds where?
sounds good though
This is what you do.
1. Go to your battery and tugg on the black wire at the battery? Is it tight, loose, broken, worn,... If worn or broken, replace it.
2. Unbolt that black wire from your battery and with a piece of sandpaper (220 grit or so) scuff the terminal on the battery and on the cable itself. What this does is make the surfaces new. Bolt it back to the battery
Do the same for the red wire +
3. find the starter and trace down the wire from the battery to that. Now tugg on it a bit. Is it tight, loose, broken, worn,... If worn or broken, replace it.
THe start the car.
fs
THe start the car.
fs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filthy_shovel »</TD></TR><TR><TD CLASS="quote">Th
excuse me if i don't know but where is the starter and how will i know that that's it(looks like what)
If you stand in front of the vehicle, the starter will be to your left, about half way down. Sorta looks like two cylinders one on top of each other like.
Maybe someone here has a pic.
fs
fs
My car would crank a few before turning on sometimes, would even make that clicking noise you were talking about. One night I was driving my car home and it turned off on me. It turned out to be my distributor. Got a new one and fixed it all up. Do yourself a favor and check yours out, when my car died on me it was night time in a neighborhood you dont wanna leave your car in.
its a starter problem for sure! if u need to get from point a to point fix, try tapping it with a stick a few times. fix it soon or it may soon be a major problem. it is east to fix and no more than 100 bucks. once fixed the car will start like a champ!
blackcivic11
06-02-2009 04:16 PM
