If I Do A Swap...
If I Do A Swap...
I am on the edge of deciding whether or not to do a swap between my d16z6 into a b16a. I would rather do a b18c1 but I dont have the money...
When I first start up the b16 and take it for a test drive will I be amazed at the difference between the stock d16z6? Or is it just a minimal difference?
Re: If I Do A Swap... (steve_s)
You will notice it up top, will pull harder. I am not a fan of b16, but they are still nice little motors. I say keep your current motor and save for a 1.8. I always say, 1.6 is nice, but 1.8 is nicer
1.6 liters was baaack then man, if you wanted to be updated with technology and what what, i say you get your C1, that thing will haul ***
and a b16 is a torqueless wonder
The difference will not be mind blowingly different. The b16 will pull harder for obvious reasons...but it wont like amaze you on how different it is. Dont be afraid of the swap though..it is worth it in my opinion. btw..what car do you drive?
Re: If I Do A Swap... (WongFeihung)
Its a 93 EX Coupe.
This is my plan for the summer, I make 4 grand.
Suspension, Wheels w/tires, and get moldings and lip painted.
How much do you think I will have left after that? Not enough for a swap I think.
So then if you guys suggest it save up for a b18c1 and swap that prob my mid to late winter and ill be set.
A little beside the point, but you might consider taking that $4k and getting a B18C1 right away. Then you can buy suspension, wheels/tires, etc. when you make extra money. I always think it's better to get the most expensive stuff out of the way first. Just think about it: Is it easier to save up $4k for an engine, or to save $1000 for wheels/tires?
But that's just a suggestion.
If you do decide to go with a B16, the difference won't be mind blowing. It'll feel like your car until 5000 rpm, since the torque on the two engines (D16Z and B16A) is pretty much the same.
Solbros Owns Me
Re: If I Do A Swap... (delsolguy)
the ONLY thing I love about the B16 is the close tranny.
I pulled my buddy's VX with a B16 in it yesteray, and I'm all motor D16Z6...basically stock. But top of 3rd he started to pull me, and then he was gone. If I had a hybrid tranny..it'd be close
Re: If I Do A Swap... (Emerika)
Alright im going b18c1 then. My complaint about my d series is torque so if the b18c1 has it then ill go for that.
Will getting the LSD tranny make a difference? What exactly is LSD anyways, I know it stands for Limited Slip Differential but what does it do?
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steve_s »</TD></TR><TR><TD CLASS="quote">Alright im going b18c1 then. My complaint about my d series is torque so if the b18c1 has it then ill go for that.
Will getting the LSD tranny make a difference? What exactly is LSD anyways, I know it stands for Limited Slip Differential but what does it do?</TD></TR></TABLE>
it allows for power to be distributed to both wheels at the same time, but allowing for one wheel to spin faster(outside wheel) than the inside wheel.
Hence, "limited"....where as POSI(positive) is equal distribution to both no matter what
if its daily driver the lsd is practically pointless...ive finally realized that
if youre going to be doing a lot of auto-x then it would be worth the extra hundreds
I went from a D15b7 to a b16a and It was a Huge diffrence ... My compression in my old engine was 150 60 70 60 though,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steve_s »</TD></TR><TR><TD CLASS="quote">Will I notice a difference in driving?</TD></TR></TABLE>
do you mean normal driving from a d16 to a b16? no.
Ive got another idea...
If I were to buy a b16 and build it up would it be worth it? I mean new cams, pistons, valves, springs, etc... Would I save money and make more power compared to buying the b18c1.
[QUOTE=steve_s]Ive got another idea...
NO. If you are already limited with funding, why would you dump money into building up a b16? Save your money and go for the B18C1..
I have a 2000 SI, trust me, go with the 18C1..
you will not be amazed at a stock b16....my friend got a b16 w/ lsd into his 95 ex....it was faster, but not that much
Re: If I Do A Swap... (DesiEg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DesiEg »</TD></TR><TR><TD CLASS="quote">fawk vtec jk
but have you considerd a b18b with a b16 tranny </TD></TR></TABLE>
i was just about to say that...if u are sorta limited on funds how bout a b18b?? then turbo that biatch later on when u get more money....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steve_s »</TD></TR><TR><TD CLASS="quote">If I were to buy a b16 and build it up would it be worth it? I mean new cams, pistons, valves, springs, etc... Would I save money and make more power compared to buying the b18c1.</TD></TR></TABLE>
No.
You would spend more money and still not have as much torque. I say, either get the B18C1, or turbo your current engine.
No.
bahhhh, i love my b16. It is however a 2 year temporary motor Then i will graduate and get a real job and a second car and a dart race block and swap my head and tranny over
