IAC 3 PIN CONVERT TO 2 PIN
Bought a d16y7 to swap into my daily driver cx hatch... motor was out of a 96 civic a buddy had i converted all wireharness and misc sensors to obd1... only problem i had was hooking the iac sensor up.. new motor had a venom intake mani with the d16y7 t/b anyone know how to convert my wiring (2wire) to the 3 wire harness iac... thanks for any help.. i will post up pics later on tonight to further clarify...
Re: IAC 3 PIN CONVERT TO 2 PIN (sin city eg6)
I too did a d16y7 but into a dx 96 hatch. Anyway go here:
http://www.jdmuniverse.com/for...inime
there's a white picture near the bottom, it explains the whole iacv thing. As for the plug go junk yard hunting. I found a harness there and most of the clips were taken by someone but lucky the iacv was still there.
I did get it running w/o the plug just to fire it up using ecu pins that I savalaged from a unused honda clips, just made sure the wire lead the right pinout on the iacv and all was wrapped in electrical shrink wrap.
i have all the clips and harnesses... thanks that **** helps alot.. if i stick with the motor im going to attempt to do the mini me as you did... thanks again!!
fordmike1980
05-30-2018 06:09 PM
eurotic1.9hatch
07-09-2008 10:40 AM
