I need some serious advice with this issue.
Old 08-20-2007, 07:24 PM
goldegg's Avatar
Default I need some serious advice with this issue.
I have a 92 VX and recently had a sloppy brake pedal that worked fine but there was alot of dead travel that had developed in it, so I purchased a brand new honda master cylinder.
I flushed and bled the system with ATE SuperBlue
After finnishing bleeding, I started the car and the pedal fell about 3" from the floor but had pressure near the bottom, with the car on pumping the pedal did not increase stiffness.
So today I went out and bench bled the master with it installed on the car with the finger plugging method (push pedal with fingers capped on the master, let one finger off the 2 holes, let the air come out of the one hole then re cover the hole and let the pedal out so fresh fluid is sucked in)
Rebled the system from back to front, started the car.
Exacally the same.
When the car is off and you pump the pedal it gets hard, but never rock hard, it will extremly slowly sink down to about half way then stop.
Any ideas?
Old 08-21-2007, 06:31 AM
goldegg's Avatar
Default Re: I need some serious advice with this issue. (goldegg)
1234
DerekHollister
24
09-15-2017 03:17 PM
EJ1B18c
02-01-2008 11:05 AM
goldegg
08-11-2007 09:00 PM
jonshonda
09-25-2006 05:17 PM
bambam
15
06-20-2005 06:14 AM
Quick Reply: I need some serious advice with this issue.
