I NEED SOME HELP IN ADJUSTING E BRAKE
I TIGHTENED THE LIL NUT ON THE DRUM BRAKE OF MY 2000 EX SO I COULD PUT THE DRUM BACK IN AND NOW MY EBRAKE IS LOOSE LIKE ITS NOT ENGAGING OR SOMETIN HOW DO I ADJUST IT??
Re: I NEED SOME HELP IN ADJUSTING E BRAKE (SOCH V-TEC)
Either adjust the nut you tightened in the drum, or adjust the cables where they come up through the floor into the center console.
You may have loosened it too much. Have you tried breaking by going back / forward a few times so the auto tensioner can work?
Also, please turn off the caps lock.
Re: I NEED SOME HELP IN ADJUSTING E BRAKE (EX_AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer »</TD></TR><TR><TD CLASS="quote">You may have loosened it too much. Have you tried breaking by going back / forward a few times so the auto tensioner can work?
You don't want to really go thru auto tensioner. Take off the drumps mark their posstion (on studs) and use a little adjuster to make them tighter.
IL SEE DA CABLES CUZ THERE IS NO WAY TO ADJUST THE LIL SCREW NUT THING WITHOUT TAKING OF THE DRUM CUZ I TIGHTENED IT SO THE DRUM COULD FIT BACK IN BUT I TIGHTNED IT A LIL TOO MUCH I GUESS ILL CHECK DA CABLES THNXS
you can loosen up DA thing too DUDE. You might also want to machine your drums, and don't mess with cables you will create big drag on your drums.
