I need help with these PCV hoses
I have pics already posted up on this other forum. Can you guys check it out and let me know if you can help? Thank you.
http://www.hondaforums.com/ind...31227
Re: I need help with these PCV hoses (alex37211)
Damn this forum is crowded. C'mon, can anyone offer any advice? I wanna get this thing done tonight. Thanks.
1 Post
First off you are refering to the EVAP system, not the PCV.
In your first pic the top nipple does attach to the Purge solenoid in the second pic.
In the third pic of the EVAP cannister you only use the two. Leave the other one plugged. One goes to the tank and one goes to the thing in the fourth pic
The fourth pic is the purge solenoid, just like the second pic, however this solenoid is more like a switch.
The difference is in the first & second pic the purge solenoid lets manifold vacuum thru to open the valve to start the purge.
The third and fourth pic's the system opens the solenoid and sucks the vapors thru the solenoid and into the manifold.
Hope this helps you out. Another thing to see if you can find is the vacuum diagram off of the GSR cars hood. It will have all the hoses for you.
