I Need help on SI swap.
I currently installed a 99 civic SI in my 96 DX civic coupe.....I used everything like to wiring harness and ecu. I am having problem with the aftermarket fuel pump not shuting of when car is not running but key is turned on, also check engine light but no codes are showing when wire is jumped, not working speedometer....Oh and does anyone have the wiring diagram to the ecu for the 99 civic SI also the stock timing.
