I just don't get it...Greddy SP on my CAR
Well, i was looking at the buttom of my car and guess what?!
WOW, i would have thought it was ripped into pieces by now. Any ideas how i can fix that? I recently bought the exhaust system from a member on board, he told me it was from his ek coupe, which i saw pictures of. seems like the hanger sits...well out too far.
this could explain why my mid section was sitting so low and why it was scrapping the ground as i went over lil bumps.
BUT THEN AGAIN....here is another reason why i prolly was scrapping the gorund
how did i manage to do that?
anyways, yah...need some help on how to fix that hanger thing b4 i chop it off!
If you can use an oxy/acetylene torch you can heat it (after removing the rubber hanger) and bend it pretty easy with some vice-grips or big pliers. It's gotta be red hot. what i do is jack it up, and use a separate device to raise the system where you want it. You have to measure and get a picture of it in your mind before the heating, bending. Then bend the hanger to where it will align with the hanger with just a liitle upward tension for lift and to compenste for sag. You're sportin' a little too much tension there!
Re: (B and B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B and B »</TD></TR><TR><TD CLASS="quote">
You're sportin' a little too much tension there!</TD></TR></TABLE>
lol...and the winner is...!!!!!!! YOU
u get the away for "quote" of the year. hahahaha. i was thinking about doing that, but im going to pull the rubber hanger off 1st and see if it sits higher, is it does, i might bend it or just go get a shop to do it. thanks for advise
gsr_to_the_MAX
12-01-2006 03:20 PM
