I just aquired a 99 civic si shell, How hard to drop in a y8 swap?
I just got a 99 civic si shell from a buddy, and have a 99 y8 swap laying around. Would this be a straight forward swap? i figure i'd use this swap for now. Things i bought for the swap already are 99 si wiring harness, ex mounts, ex ecu.
Re: I just aquired a 99 civic si shell, How hard to drop in a y8 swap? (boo bees)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boo bees »</TD></TR><TR><TD CLASS="quote">Bwuhahaha. Are you serious?</TD></TR></TABLE>
was this necessary? the guy got a civic shell, and needs something to put in there so he can drive it...the fact that it is an si shell doesnt really matter.
anyways to the op: the y8 came in 96-00 ex civics, so it should be pretty straight forward. but someone else may have a more informative answer for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boo bees »</TD></TR><TR><TD CLASS="quote">Bwuhahaha. Are you serious?</TD></TR></TABLE> yeah ummm... whats so funny about him trying to put a motor in a shell... is it because he has to put a MAD TYTE JDM B16!@! because he has an si?... and yes basically its a straight swap
Re: I just aquired a 99 civic si shell, How hard to drop in a y8 swap? (Yodastien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yodastien »</TD></TR><TR><TD CLASS="quote">i dont know bout you but ild rather have a d15 b than a y8</TD></TR></TABLE> why would he want to go thru the trouble of making it obd-1 when he has a straight drop in obd-2....
Re: I just aquired a 99 civic si shell, How hard to drop in a y8 swap? (fizeks)
Its a direct drop in if you have all the y8 mounts, harness and ecu.. also sohc shift linkage
yeah ud need the dseries mounts, but event hen i dont know exactly if the mounting points are the same, since teh si came with a b-series motor. if i were you i would just wait for a bseries motor and not waste time tryna put a y8 in there, could be more trouble then its worth.
Re: (menappi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menappi »</TD></TR><TR><TD CLASS="quote">yeah ud need the dseries mounts, but event hen i dont know exactly if the mounting points are the same, since teh si came with a b-series motor. if i were you i would just wait for a bseries motor and not waste time tryna put a y8 in there, could be more trouble then its worth. </TD></TR></TABLE>
its not any trouble.. direct bolt in .. only mounts that are different are the rear "T" bracket, front TQ mounts and timing belt block mount.. which all you do is just use the sohc mounts that the y8 has.. boom direct bolt in
Re: (Timmay)
id prolly take the dohc and the si emblems off for the time being. theres a guy perpetrating like that around here on a hx civic, and gets clowned everywhere he goes. but i do understand your need for a car that actually moves and is usefull. good luck with you swap.
Re: (JSPECSIR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECSIR »</TD></TR><TR><TD CLASS="quote">id prolly take the dohc and the si emblems off for the time being. theres a guy perpetrating like that around here on a hx civic, and gets clowned everywhere he goes. but i do understand your need for a car that actually moves and is usefull. good luck with you swap. </TD></TR></TABLE>
lol good way to get a HX stolen lol...immagine their surprise when they pop the hood. i bet it was stolen 50 times and just braught back, due to dissapointment
Re: (JSPECSIR)
HAHA. I saw an EX at my school parking lot with the stickers AND the rear badge. I had to do a double take. Definitely wasn't from Canada either.
Anyways, I see nothing wrong with making a useless car into a useful one. GL with the Y8.
Re: (JSPECSIR)
I'd say I know who you're talking about, but I'm in Jacksonville.
To the OP: Bolts right in with the above said mounts. It runs, and you can always save up for a better motor.
Re: (JSPECSIR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECSIR »</TD></TR><TR><TD CLASS="quote">id prolly take the dohc and the si emblems off for the time being. theres a guy perpetrating like that around here on a hx civic, and gets clowned everywhere he goes.</TD></TR></TABLE>
HAHA. There's a guy around here (Jackson, MS) doing the same thing. LOL. Its a silver 96-98 HX.
Ek Forever y0!
Re: (PhatBoy5015)
WTF why would he get a d15b when he's already got a spare y8?
GL with the swap, it should be a slice of pie.
Re: (civic123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic123 »</TD></TR><TR><TD CLASS="quote">YOU WANT TO SALE THE BODY!!!!!!!!!!!!!</TD></TR></TABLE>
like sail it on a lake?
Yeah. He should get one of those. For his 99 si (obd2) shell. when \/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tousi »</TD></TR><TR><TD CLASS="quote">have a 99 y8 swap laying around. </TD></TR></TABLE>
NooB
the intake manifold on the y8 is the best stock then a little d15b.the y8 is 1.6L sohc vtec.Way better then a d15b.gl on the install.
Re: I just aquired a 99 civic si shell, How hard to drop in a y8 swap? (2k.civic.si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si »</TD></TR><TR><TD CLASS="quote">the wiring will be fun ....hardest part of the swap</TD></TR></TABLE>
there will be no wiring involved in what he wants to do if he has the y8 harness
Re: I just aquired a 99 civic si shell, How hard to drop in a y8 swap? (Timmay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">
there will be no wiring involved in what he wants to do if he has the y8 harness</TD></TR></TABLE>
that be true
that be true
Alex_G
10
08-27-2006 01:28 AM
