i got a question
#26
Unceasing Measure
Re: i got a question (GsR92HaTcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsR92HaTcH »</TD></TR><TR><TD CLASS="quote">hmmm gas tanks are vented so there wouldnt be any explosin soo even it i said putin it strait into the tanks it isnt that much of a bad idea since dry ice when it melts turns into gass not water like ice and it would just be vented out...its not like a gas can that hold all its pressure in </TD></TR></TABLE>
Dry ice doesn't melt, it sublimates. Sublimation is the process of a solid turning directly into a gas. Melting is the process of a solid becoming a liquid. H2O ice melts, CO2 ice sublimates.
A cool-can will be fine and will do no harm to your engine, but unless you're running some super aggressive timing, compression or boost, it's not going to make any difference at all without significant changes in any of the three aforementioned characteristics. It's physics and chemistry
#29
hey buddy notice how later on in the forum i said i didnt mean litarly into the gas tank i meant liek through a cooler can...adn the ppl who are talkin about it explodeing the tank tahts not true either cuz think about it you go to teh gas station u fill ur tank up and u go driving around ur gas is sloshing and what not everything gettin all hot n stuff and when u take the gas cap off wheres all the pressure???hmmm gas tanks are vented so there wouldnt be any explosin soo even it i said putin it strait into the tanks it isnt that much of a bad idea since dry ice when it melts turns into gass not water like ice and it would just be vented out...its not like a gas can that hold all its pressure in </TD></TR></TABLE>
If you want cooler fuel, add a cooler to your fuel line.. They are available and inexpensive and EASY to install. It's similar to a tranny or oil cooler. Don't put dry ice in-on-or near your gas tank, ok?
#30
Re: i got a question (hondapowa)
CALL IT INTO MYTHBUSTERS!!!!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondapowa »</TD></TR><TR><TD CLASS="quote">
If you want cooler fuel, add a cooler to your fuel line.. They are available and inexpensive and EASY to install. It's similar to a tranny or oil cooler. Don't put dry ice in-on-or near your gas tank, ok? </TD></TR></TABLE>
^^hasn't this been mentioned already....try reading the post before opening your mouth pal
