Hybrid break setup
Hybrid break setup
I'm planning on doing some brake system upgrades soon. If I put an ITR brake booster and master cylinder on my 92 civic, will it stop better without changing anything else? I have the smallest front rotors (9.something) and rear drums.
I'll eventually get to the rotors/calipers upgrades but since my master cylinder is starting to leak, I wanted to know if replacing the booster+cyl will make any difference in breaking.
Also, if you know where I can get the booster+cyl as a combo for cheaper, I'd like to know.
Thanks!
Thanks!
Moderator
Re: Hybrid break setup (bradykiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bradykiller »</TD></TR><TR><TD CLASS="quote">I can't be happier with my hybrid brake setup, all oem parts 11.1inch rotors :D 4x100 lug.</TD></TR></TABLE>
ditto...x3 since all my cars have that setup!!
Re: (civic_driver)
His talking about MC/BB only while on stock brakes. I heard from a reliable source on H-T that if you upgrade MC/BB with stock brakes you wont get much of a stopping power until you upgrade to integra's. So i dont think youll notice much off of it but a stiffer pedal.
Itll bolt up no problem.
^only if its abs (I did not reflare)
Only changing the mc/bb will increase pedal firmness and mild braking. Its like using a semi truck to move a shoe box.
Upgrade the calipers, rotors, and mc/bb to get the most out of everything
i will but i'll be doing it one at a time as money comes my way... i don't want to reflare any pipes for now so is there a 1" mc that doesn't require reflaring? if so, what booster do I use with it? If not, what's the best MC i can use without reflaring lines? I'm willing to bend a few if i have to... so i'm guessing the mc has to come from a non-abs car but which one?
it's a 92 civic dx
thanks!
it's a 92 civic dx
thanks!
details?
details?
yeah, more info please
if you have other than stock setup, please post your vehicle info (e.g. 92 civic dx) and then post the brake setup that you have and what you had to do in order to put that setup in your vehicle.. hopefully this will be useful for others as well!
thanks!
thanks!
I used the itr 1" mc/bb setup (no reflare)
Integra calipers
10" front rotors
rear disc conversion
em1 prop valve
to use the 11" you will need to redrill itr or prelude vtec rotors to 4x100
Integra calipers
10" front rotors
em1 prop valve
Re: Hybrid break setup (t0ekn3e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0ekn3e »</TD></TR><TR><TD CLASS="quote">
details?</TD></TR></TABLE>
I'm running an GSR 1" MC with my stock Civic Dx Brakebooster and stock prop valve (same stock number as the 99-00 SI brakebooster/4040prop valve.)
01 GSR rear disc brakes, and in the front i switched to 01 GSR Front knuckles, with redrilled 92-96 Prelude VTEC rotors, with ITR Calipers modified to fit on the GSR Knuckles, you have to shave a couple mm off the caliper mounting bracket, or use spacers.
And here is the end result, 15 inch rim, with an 11.1 inch rotor.. stops on a freaking dime.
HT Order of Merit
Re: (civic_driver)
If you do your research, there are endless things you can do with the brake setup using simple OEM parts. From the big rotor conversion as shown above, to mating NSX calipers on, to a poor mans 5 lug conversion.
Re: Hybrid break setup (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">How the hell did you get a GSR MC on a Civic DX BB? </TD></TR></TABLE>
They bolt right up to the 96-00 mc's, just not the 92-95.
Most dc mc's Ive seen are diagonal mounting, ek bb's are horizontal. I dont see how theyd mount up. Are the stud offsets different between the dc years?
whether its for an ek or eg, does not matter.
Your eg can have the same brakes as any ek setup. Which explains how I can use integra sets on my ek.
it doesn't matter but it does affect the work required to install the setup... i.e. bolt on or modification required to do setup
boostedcivic, are those 15" wheels? what tires? what rotor, caliper, master cyl and booster did you use? also, what knuckle?
No, it doesnt. As long as youre knuckles are from a car that uses 10" rotors, everything will bolt right on.
I installed everything without modifying a single part (minus bending a hardline)
so you are saying that in my 92 civic dx i can put the following:
Integra calipers
10" front rotors
em1 prop valve
and all i have to do is bend the brake lines?
hmm, if so, that's the setup i'm going for
btw, why do the itr 11" rotors need to be redrilled? is it because of the 5 lug to 4lug conversion? or why? where can i get it redrilled?
Integra calipers
10" front rotors
em1 prop valve
Re: (civic_driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_driver »</TD></TR><TR><TD CLASS="quote">so you are saying that in my 92 civic dx i can put the following:
Integra calipers
10" front rotors
em1 prop valve
btw, why do the itr 11" rotors need to be redrilled? is it because of the 5 lug to 4lug conversion? or why? where can i get it redrilled?</TD></TR></TABLE>
No, I said if you have knuckles that use 10" rotors - you have 9", so you will need knuckles from an integra, civic si/ex/abs, or del sol vtec.
After that, you will need to find a non-abs 1" mc (in order to not reflare, which isnt even a big deal anyway).
The rest is yes. (But you'll probably want a different prop for an eg, since the em1 is modeled for ek's)
Everything youre asking has been covered many times, and if you searched, youd find it all fairly quickly.
11" honda rotors only come 5 lug, this will not fit 4x100 (your car, my car, almost everyone's civic). If you convert to 5 lug, you will not have to redrill anything...since you converted to 5 lug...
Most shops will not redrill rotors, since there is so much room to screw up. Personally, for the size, I cant really see any advantage of itr calipers over the other integra ones..they already lock up very easily on my coupe and will do it faster on a hatch.
Please search for more info. Its there.
Integra calipers
10" front rotors
em1 prop valve
