how is the stock headunit mounted in a 96-98?
hey guys
sorry i know this isnt really "technical" but replies come wayy faster than it does in the a/v section.
yesterday i restored my old factory headunit into its spot, i got tired of the aftermarket headunit look, and the stock one flows much better with the interior.
however, since installing my headunit last summer, i dont remember if there is supposed to be any mounting places to screw a screw into the headunit to keep it in place... right now its just sitting there and ocasionally pops out.
any ideas?
thanks
any ideas?
thanks
Re: how is the stock headunit mounted in a 96-98? (ekcivic9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 »</TD></TR><TR><TD CLASS="quote">hey guys
any ideas?
thanks</TD></TR></TABLE>
I belive there are screws.... pull off the panel with the accesory jack, don't know what the whole panel is called, and I belive you screw upwards.. if you know what i'm saying...
any ideas?
Re: (ekcivic9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 »</TD></TR><TR><TD CLASS="quote">thanks g2, ill go look into it when i feel like ripping everything apart again till now, ill just push it in every so often </TD></TR></TABLE>
I'm pretty sure!!.. I'm not guaranting that it's there but I do know it screws in. it could either be at the side.. or below...
GL
GL
I do this all the time, the 2 screws that hold the headunit in place needs to screw into the bottom of the head unit. When you slide the head unit into the metal frame, there are 2 holes for u to screw into the frame and into the headunit to secure its position.
Good luck!
Good luck!
Re: how is the stock headunit mounted in a 96-98? (SPD DMN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPD DMN »</TD></TR><TR><TD CLASS="quote">I do this all the time, the 2 screws that hold the headunit in place needs to screw into the bottom of the head unit. When you slide the head unit into the metal frame, there are 2 holes for u to screw into the frame and into the headunit to secure its position.
Good luck!
yay i was right!!
Good luck!
yay i was right!!
Re: how is the stock headunit mounted in a 96-98? (G2 Speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed »</TD></TR><TR><TD CLASS="quote">
yay i was right!!</TD></TR></TABLE>
No I was right
No I was right
Re: (slowEKcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowEKcoupe »</TD></TR><TR><TD CLASS="quote">http://www.handa-accessories.c...o.pdf</TD></TR></TABLE>
hmm... that doesnt look like the right dash for his 96-98 civic... heres the link I used, everything was 100% accurate and easy
http://www.installdr.com/Insta...3.pdf
This should clarify everything you need to ask
GL
GL
Extreez
07-31-2006 06:15 AM
RSXisS
02-18-2005 07:04 AM
BlueFang08
01-12-2005 01:41 PM
