how to remove a sohc tranny??
Risky Business
Re: how to remove a sohc tranny?? (-BEN-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -BEN- »</TD></TR><TR><TD CLASS="quote">Its fairly simple.</TD></TR></TABLE>
Simple, but time consuming. And if you **** up like I did it's even more time consuming.
Don't call it a comeback
Re: how to remove a sohc tranny?? (BauleyCivic)
Been there, **** sux too
When you are putting everything back together, make sure the bolts go in properly. Dont get too excited or anything. also, remember the grounds.
Risky Business
Re: (Darren 92 civic)
Also if you dont have a helms manual get one. It is an absolute essential for this job.
http://www.helminc.com/helm/pr...19NK5
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">
Simple, but time consuming. And if you **** up like I did it's even more time consuming.</TD></TR></TABLE>
i remember that.....like pulled it 4 times right!!
Risky Business
Re: how to remove a sohc tranny?? (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">
Nope. Pulled it, put it back together ENTIRELY. Put the car on the ground...go to start it...shifter wont move back and forth. Had to do it ALL over again because i bent the shift arm with the interlock guide bolt. Worst weekend of my life.
took my tranny out a month ago. thought it would be a few hours. turned out to be 5 hours. not very hard. lot of bolts but time consuming. use bags for your bolts.
Risky Business
Re: how to remove a sohc tranny?? (94 civic all mtr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94 civic all mtr »</TD></TR><TR><TD CLASS="quote">that **** easy took me 30 min</TD></TR></TABLE>
Not with hand tools and jackstands it didn't.
How many have you done? I work on these cars in my shop an it still takes me an hour to do this with air tools and a lift I think you are exagerating just a little.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">Alright then congrats.</TD></TR></TABLE>
Yeah...the first time I took out my tranny It took me 2 days of located parts, and all kinds of bullshit. Second time took me 5 hours...in...and....out....Cuz I learn from my mistakes.
GDD Member
Re: how to remove a sohc tranny?? (reward_1000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reward_1000 »</TD></TR><TR><TD CLASS="quote">How many have you done? I work on these cars in my shop an it still takes me an hour to do this with air tools and a lift I think you are exagerating just a little.</TD></TR></TABLE>
I do 2 or 3 a day.
4 nuts and 2 bolts for axles
2 bolts for starter
8 or so bolts for tranny
6 nut/bolt for tranny mount
Wires- A couple ground wires, Speed sensor, reverse light, (I remove distributor/upper radiator hose for quicker time).
2 bolts for slave cylinder, 2 more for slave cylinder hydraulic line.
4 bolts, flywheel cover
*Auto Trans- 8-10 torque converter bolts.
If you think about it, it's under 30 nuts/bolts, so it isn't really that hard. I change clutches in around 2 hours working alone, quicker with help. I use air tools, lift, and floor jack for auto trans/tranny jack on manual trans'.
I do 2 or 3 a day.
2 bolts for starter
Risky Business
You're not the only one. Unless he worked constantly and didnt stop for a Pepsi break every 15 mins like me. Like it takes 30 minutes to do everything once you get the car up on a lift...but I like to take my time with things and would probably take me an hour or two just to get the thing off.
Risky Business
Re: how to remove a sohc tranny?? (EF9_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9_SiR »</TD></TR><TR><TD CLASS="quote">get a die grinder and go to town.</TD></TR></TABLE>
What?
What?
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9_SiR »</TD></TR><TR><TD CLASS="quote">if you do enough cutting its bound to come out,</TD></TR></TABLE>
or you could just drive it off a cliff
jlamaster
11-22-2003 05:11 PM
A D NOH
07-22-2003 10:54 AM
