HOW TO: My auto to manual swap PICS! 56k no no.
#52
Re: HOW TO: My auto to manual swap PICS! 56k no no.
can i just cut the reverse switch completely off the harness & run the wires to the 14 pin connnectorthat should work right???
#55
WOW!! great write up man! but i used the same throttle cable, maybe thats why my gas pedal is too high up?!!?? and im just buying a new wire harness.
#58
im getting ready to finish mine up currently. mine is a 92 dx hatchback. the car is currently running with the auto engine harness, on a d15b2 obd0 engine. soon to have a y7 head. also, for the trans mount, ill be making a custom mount myself out of steel and window weld.
#59
#60
I was wondering does anyone in here know a shop or someone rebutable that does these trany swaps in miami or ft lauderdale?
#61
its the only motor i had at the time besides my rebuilt d16a1 sitting in the garage. plus i know this is very reliable with over 200k on it and burns very little oil. also, its getting a d16y7 head in a couple weeks to bump the compression up to 11.3 to 1. and possibly, here later down the road, ill put my d16a1 in with my turbo kit that im planning on doing.
#62
what chassis, motor, etc? I did mine with help from my dad, I could help you with yours if your local. Or if you just want someone else to do it maybe me and him could do it for you for a reasonable price.
#63
I have a 94 dx coupe, i dont have any parts for the swap but im willing to pay if you and your dad or whatever to do it for me....i dont have anytime to do it on my own...
#64
If your serious about doing it then make a WTB thread on HMP and search craigslist for the parts.
#65
do you really need the auto to manual conversion mount? or can you just get the mount from a manual car?
#66
Seagull Management
You need the manual pocket mount off a manual civic (the one thats welded to the frame rail) plus the upper transmission mount that bolts to the pocket mount and the top of the transmission to do it this way.
#67
see i only used the inside part of the mount for my car. I didnt change the piece that was welded to the frame.
#68
Seagull Management
And wasn't yours a '96 - '00 civic? Completely different animal in that regard. You flat out can't use the original automatic pocket mount on a 5th gen and not have the engine sitting funny and not have axle problems.
#69
I figured you could do the same thing on a EG.
#71
i think im going to try this, this weekend. i dont need to worry about the tranny/clutch/mount issues as i have eveyrthing for my K, just need to make the shell ready for it. great info.
#73
i have a question, i am doing the swap in my 92 civic...i have the clutch assembly in...i took out my brake/gas pedal assembly and compared it to the one im putting in, the clip that attaches to the brake is different. on the auto assembly it is 2 pins, in the manual one it is 4 pins...is that what happens, or do i have a different year assembly??
any help, would be appreciated.
#74
Dont swap out the whole assembly. I just swapped out the pedal itself. That way you dont have that issue.
#75
