How to make car beep when lights are left on?
I have a 1995 Civic Ex and want my car to beep indicating that I have left my headlights on.
Anybody know how to do this?
Re: How to make car beep when lights are left on? (2camsaam)
no civic before 96 that i know of beeps when your lights are on and ignition off, theres probabley a way to wire up an alarm or somethin
Bah there was a site for doing this to a Del Sol, and i did it on my 92 hatch over break. Its really easy, just a 5 dollar relay from radio shack and some wiring...... The site is gone though.... I might still have the directions though, if i find them i'll scan and post them.
Re: How to make car beep when lights are left on? (splitime)
when i hooked up my cd player i accadenlty hooked it up so that when my lights are on my cd player is still on. works good for me
Re: How to make car beep when lights are left on? (92civicsi)
I believe I have seen a thing at wal-mart in the automotive section that you could use. Like a headlight left on reminder kit? I saw it by the toggles and butt conectors. Or you could buy on off ebay too.
Re: How to make car beep when lights are left on? (flat-blk-HB)
OK
This is assuming you have above average intelligence.
Tools you will need include:
Test Light
Wire Strippers
Soldering Iron
Wire Crimpers
Razor Blade or Olfa Knife or Box Knife
Materials include:
Some sections of wire at least 18 guage
Some female "speaker" terminals
A Bosch (or equaivalent) 12 Volt 30 Amp Relay
Some kind of beeper or buzzer that works on 12 Volts or higher
Electrical Tape - Dont be cheap buy 3M
Some Butt Connectors - Red or Blue (indicates guage)
Ring Terminals
Self tapping screws
First you will need to locate the parking light wire. You are actually trying to indicate headlights, but if your headlights are on your parking lights are too. You will ground one end of the test light and "probe" around for the wire. You can switch the parking lights on and off to be sure you got the right one.
You should be looking under the drivers side dash. Places the check are at the bundle of wires that run into the steering column and near the fusebox. If all else fails you can tap directly into the parking light wire and run it into the car. I dont suggest this. You could pull the parking light and look at what color the wires are and then look for one of those colors inside under the dash. If you cant find it you probably couldnt hook it up anyway...
OK, so you found the wire...you did find the wire, right? Cut a slice into the insulation of the wire about 1" long and peel the insulating jacket off. Attach one of your sections of wire here about 1 foot long. Either solder it and tape it, tape it, or if all else fails use a butt connector (which I am not a fan of, soldering is best). Make sure your parking lights are off at this point. Now crimp one of your speaker terminals on the end of this wire, along with another short jumper wire, as indicated by the red wire and jumper in the diagram.
Now take another piece of wire, perferably black and connect this to ground with either a self tapping screw or use an existing screw.
Look on the bottom of the relay and make the following connections. I could be wrong with the labeling of the numbers but it really doesnt matter, its just the labels. The main thing is dont use the center pin on the relay, as it wont work and there is a chance for the whole thing to short out if the center pin touches metal.
At this point if you cant follow the diagram you are fugged...plus I am tired of typing.
If anyone else needs a custom relay design just IM. Good Luck!!!!
Jon Black
http://www.blotterart.com/ebay/relay.jpg
[Modified by Jon Black, 4:48 AM 2/23/2003]
[Modified by Jon Black, 4:49 AM 2/23/2003]
Test Light
Wire Strippers
Soldering Iron
Wire Crimpers
Materials include:
Ring Terminals
Self tapping screws
Jon Black
the method i ended up using required a relay from radio shack, and 4 wires with connectors to attach to the relay. Thats it. It hooks into the keys in the ignition warning beeper. I just have to figure out if i kept those darn instructions.
Jon Black
Re: How to make car beep when lights are left on? (Jon Black)
Ebay sells those buzzer thing for $.99 i think. Or you can go buy all the parts at radioshack.
Re: How to make car beep when lights are left on? (HyBriDcxR)
You DON'T need a relay, just get one of those $2 kits from walmart or wherever. They tell you exactly in your fusebox where to put it.
Re: How to make car beep when lights are left on? (CXHatchback)
Yeah I will be going to walmart later today and will look and might pick one up for the hell of it.
Well, if you DONT leave your keys in the ignition, but DO leave your headlights on, then your buzzer wont buzzzzzz...
Jon Black
Jon Black
Read this thread. On the second page I have pics and an audio file of the buzzer I got from Radio Shack.
http://66.81.7.238/zerothread?id=290569&page=1
The easiest way of doing this, is to buy a 12 volt pulsing piezo buzzer from Radio Shack part#273-066a, about $5.00, an inline fuse holder and a 3Amp fuse.
Now to install this buzzer. First ,you will see that the buzzer has 2 wires, a black and red wire. Solder your fuse holder to the red wire. This red wire will tap into your parkink light fuse, that way it will sound if you leave your parking lights on. The black wire will be tapped into your wiper fuse. Now insert your fuse, turn your key to acc, turn on your parking lights, and turn your key to the off position, if done correctly your buzzer should go off. Secure your buzzer to the vehicle and your done.
Re: How to make car beep when lights are left on? (XKWISIT1)
The idea of this project is to notify you when you leave your lights on when you leave the car, which I am assuming that you will turn your ignition off and remove the keys.
The headlight fuse should show power on both sides of the fuse with the key on or off. I believe it runs through the headlight switch AFTER the fuse, but I could be wrong as I havent checked.
Jon Black
Found it in WallyWorld aka Wal-mart for $6.79, installed in like 20 minutes.
Hardest thing to do, which really still wasn't to difficult was to find a fuse that would shut off the buzzing if the lights were on while the car was on. If I didn't do this anytime the lights where on, whether the car was on or off, it would make the buzzing noise.
I connected the red wire to the parking lights fuse/interior dash lights fuse, and the white wire to the SRS fuse.
Works fine, thanks guys.
ladybender
06-21-2007 10:01 PM
blkEFhatch
Audio / Security / Video
10-24-2003 10:39 PM
