how to hollow out a cat
Re: how to hollow out a cat (chadalac1712)
Easiest way would be to unbolt it, but depending how your cat is set up, you may need to hack saw it off an inch or two down the pipe away from the cat, and then you want a really long heavy duty screw driver (flathead) or a cro-bar. Just stick the screw driver or cro-bar into the car and swirl it around abit and it should knock the honeycomb type stuff out. Or if you have someone who's really good at welding, cut the cat in half, hollow it out and have that person re-weld it back together.
Re: (doood)
Unbolt your cat, turn that thing vertically, put one foot on each end of the flange and grab and drill and have at it (make sure you secure it, if it catches it will spin and mess up your shins). Worked for me and it only took about 10 minutes. A long screw driver will help push out the small chunks.
Re: (95ProjectEJ1)
I wouldn't buy a brand new one to ruin, I mean if you're gonna buy a brand new one I'd put it on and use it as it's supposed to be used. Myself I'd yank one from another car, (or use your own old one) and hollow that one.
Re: (InvaderTrax)
Gget a long broomstick, climb up a ladder, shove it up your ***, then jump.
A hollowed cat causes turbulence resulting in restriction in the exhaust resulting in a decrease in power. Search. Even a test pipe gives you a max of 2 hp on a highly modified engine. Is it worth the damage to the air we breathe?
Bad smell, black bumper, crappy exhaust noise, reduction in the ozone layer...
Re: (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch »</TD></TR><TR><TD CLASS="quote">Gget a long broomstick, climb up a ladder, shove it up your ***, then jump.
Bad smell, black bumper, crappy exhaust noise, reduction in the ozone layer...</TD></TR></TABLE>
*thud*
*thud*
Audio28
11-16-2002 03:38 PM
