how to get the 4 lug Jspec ITR wheels to work on the EG?
New User
I have seen many of the wheels but they are 4x114 pattern. What do I need to make them work for my 92 Civic HB?
Thanks
Thanks
1 Post
Re: how to get the 4 lug Jspec ITR wheels to work on the EG? (b20z)
same thing as a 5 lug conversion..
Not exactly sure how it works on EG/DCs...
1. Rear ITR LCA's (depening on what kind of shock you want. If you want to use an ITR shock, you need these. If you want to use the stock Civic shocks, you use the stock Civic LCAs.
blah blah...there is more that I can't remember..
here is a link that explains it all..
http://www.hybridautomotive.com/tech/5lug/
New User
Re: how to get the 4 lug Jspec ITR wheels to work on the EG? (fowler)
cool thanks, I like the 4 lug ITR wheels kindda looks like the RH CPR
thanks for the info
thanks for the info
Re: how to get the 4 lug Jspec ITR wheels to work on the EG? (Mario)
I thought 96 ITR brakes = Early Prelude brakes.... (11" rotors) ????
No LCA's needed for the swap..
but you need--->
Front- knuckles, discs, calipers, wheels.
Rear- trailing arms with the parking brake cables, discs, calipers and wheels
there is a guy on the DFH list/site that has this setup, Jesse at hondatwincam.com I believe
but you need--->
Re: how to get the 4 lug Jspec ITR wheels to work on the EG? (ALL_MOTOR_EK)
why wouldnt they be? y would they make adaptor if they weren't safe?
if you dont want adaptors get the whole suspension.
Won't that push the wheel out too far? rubbing?
That's ghetto.
Here's the specs on the wheels:
Offset = 50mm & Bolt Pattern: 4x114.3mm
Acura Integra Type-R (JDM 4-bolt) Cast 15x6 (12.3 Lbs)
Acura Integra Type-R (JDM 4-bolt) Cast 16x7 (17.0 Lbs)
New User
Re: how to get the 4 lug Jspec ITR wheels to work on the EG? (Honda4CX-R)
I like them, so the prelude suspension will bolt right up with the 92 civic chassis?
If I use the prelude suspension , what year will work?
[Modified by b20z, 10:48 PM 6/12/2002]
Re: how to get the 4 lug Jspec ITR wheels to work on the EG? (eg-six)
So how big are the 96 spec ITR brakes?? 10.3 or 11.2??
Like I said, just like the GSR or newer Si
markpaco
06-27-2011 12:42 PM
C4wrx
09-06-2002 01:12 PM
