How do you remove the timing belt from the cams?
Sorry im new at this, but im at the process of removing the cams, but cant remove them yet until i remove the belt. i know theres something im suppose to loosen first to remove the cams but not sure where its at. I got a b16 motor.
Re: How do you remove the timing belt from the cams?
They have a hole inthe timing cover, usually right around engine mount...timing belt tensioner...i believe its a 12 or 14mm bolt
you dont have to take the engine mount off. but must take off some accesories if you have them. also its a 14mm socket you use.
only loosen it a little then the belt with have some stretch
Mad-Mike
06-02-2011 07:35 PM
crxh22project
02-21-2005 07:49 PM
