How do you remove the key solonoid?
New User
I need to know how to remove the key ignition solonoid (the part the key goes into) in a 96-00 civic. My uncle is a lock smith and he is going to rekey it for me.
The reason i want to re key it is, the car was broken into before and the ignition was tore up, so now i have 1 key for the doors/trunk, and 1 key for the ignition. I just want 1 key for everything.
If you think this may cause a security issue with the answer being posted, please PM it to me or email me BClaps@twcny.rr.com
Modified by BrandonClaps at 3:44 AM 11/17/2003
Re: How do you remove the key solonoid? (BrandonClaps)
The part the key goes in isn't the solenoid. I think you got to pull the wheel and take all that stuff off.
You have to remove the plastic interior pieces,drop the steering wheel 2 bolts hold it up,when you drop the wheel you will see a strap around the collum w/ 2 bolts.Cut or drill the bolts holding the strap.I had to cut the strap w/cutt-off disc to remove it.
Re: How do you remove the key solonoid? (fkned)
YES WE KNOW HOW TO DO THAT.....
WE JUST WANT TO KNOW HOW TO REMOVE THE CYLINDER WHERE THE KEY ACUALLY GOES IN <<<< NOT THE HOUSING....damn, i hate when i have 2 raise my voice, lol
Re: How do you remove the key solonoid? (xerox445)
well, I'M SORRY IF I MISUNDERSTOOD YOU,WHY DONT YOU TAKE OUT WHATEVER IT IS UP YOUR *** AND RELAX,I WAS TRYING TO HELP.Just because someone post either old or not needed info DOSEN'T MEAN YOU HAVE TO BE AN ******* ABOUT IT. here have a and relax.
Its actually a peice of cake.. Im not sure if you're able to do it with the ignition still on the column.. I always do it when its off.. But with the original lock thats in the ignition now you turn the key to on position theres a little button on the ignition somewhere you need to get a small scredriver or a nail or something and push that little button in now the lock should just slide right out.. Some times theres a star screw thats on the ignition too, if thats there that also needs to be removed.. I'll try and shoot some pics to give a better explanation
SavMac14
04-02-2013 09:35 AM
