how do i replace DASHLIGHTS on my 96 EK???
Location: Land of the Hillbillies and Shotguns, Ontario, Canada
Hey guys, i searched and could not find. How to I remove my A/C control cluster panel so I can replace the light bulbs?
[IMG] [/IMG]
[IMG] [/IMG]
Re: how do i replace DASHLIGHTS on my 96 EK??? (Rayz_Si)
Re: how do i replace DASHLIGHTS on my 96 EK??? (Kwayzie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwayzie »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1186091</TD></TR></TABLE>
Thanks....That thread is going to help me out a lot............
Re: how do i replace DASHLIGHTS on my 96 EK??? (sohc'd upEJ8)
Damn! the pics don't work. Well i have an idea atleast now
I wanna bump for some how-to threads with working pics please!!!!!
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rayz_Si »</TD></TR><TR><TD CLASS="quote">I wanna bump for some how-to threads with working pics please!!!!!</TD></TR></TABLE>
pics work for me!!
pics work for me!!
Re: how do i replace DASHLIGHTS on my 96 EK??? (alispoon)
Hey, the pics do work now, wow what a nice write up!!
Re: (t0pnotch1)
read the post, the link is one this pafe somewhere on the top. They used amber 24 bulbs, but said there will be a fitting problem, it's okay though the light will light up
Re: (Rayz_Si)
Thanks alot for the help guys I just did the dashlights today lol after like 8months finally got some time 9:30 in the night, took tmy time and did it right.
I actually got slightly used bulbs out of a used dash cluster on a 01 civic. My stock a/c bulbs actually have blue caps on them, but emit a clean white light. I carefully slid them off (one tore a little was melted to bulb) and slid them on the new bulbs.
I accidentaly tried to disconnect the heat control cable from the switch assemble, nono i was supposed to take it off fromthe other end of the cable which goes to the heater core box. I had to re-read that hoew-tothread in the link above.
All said and done, thank god I don't have to turn on my interior light every time i need to change the temperature, I can see what im' doing now.
Re: (thizzed_out_civic)
Ohh yeah this is one of those jobs you just gotta take your time and do it, definatly a bitch and takes some patience.
On the note, when re-installing the heat control cable check the movement of your hot-cold switch. If movement is limited try disconnting cable and moving switch all the way to cold, then hook and clip on the cable and should be good to-go!
My 4-way flasher bulb is out, that I have to order from honda. It's like the tiniest bulb in the world if you ever saw it. Keeping up all these details in your car really makes it feel like a new car.
HT White Ops
Gauge Lighting:
EX Cluster:
5x #24
1x #194
2x #74 (optional) for downward illumination)
Lighting for Climate Control:
2x #74
Buy glass bulbs, not LEDs, they just look more natural, and spread correctly.
get them @ http://www.autolumination.com
Also, don't disassemble the climate control. Just take off the lower 12v socket pannel, and reach up there and pull the socket out. It hurts your hand, and it's hard, but nowhere near as time consuming as taking out the climate control.
EX Cluster:
5x #24
1x #194
2x #74
HT White Ops
Re: (Rayz_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rayz_Si »</TD></TR><TR><TD CLASS="quote">My 4-way flasher bulb is out, that I have to order from honda. It's like the tiniest bulb in the world if you ever saw it. Keeping up all these details in your car really makes it feel like a new car.</TD></TR></TABLE>
Neo-Wedge twist outs. They work for cruise control, OEM foglight buttons (not esuse or depo), hazards, and defog.
Best bet is to get them from honda because the 10mm neo-wedges they have on autolumination are too big. They come in four different colors from honda:
Amber (white condom) - on/off indication for defrost + jdm foglight on/off indication
BULB - 35850-SV4-981
99-00 Climate Control Neo-Wedges:
BULB, NEO-WEDGE - 79609-S02-A01 (blue condom)
BULB, NEO-WEDGE - 79609-S02-A11 (amber condom)
Greenish-White (blue condom) - defrost illumination for 96-98 civic cx/dx/lx/ex
BULB (BLUE) - 35850-S04-003
Green (green condom) - oem foglight on/off indication + cruise control
BULB (G) - 35852-ST3-G01
Clear (no condom) - hazard illumination
BULB, NEO-WEDGE (CLEAR)(TEC) - 35851-SM4-003 <-- it's that one!
Re: (Eran)
Thanks so much for the great help, info and insight!!!! all of you.
I just visited autolumination.com and firgured i'd change my A/C controls to blue, as well as my dashlights blue.
As for my girls EK im' hooking her up with some purple AC control bulbs, since hers need to be changed
kay_animation
Mid-Atlantic (Sales)
152
04-06-2008 12:41 PM
