How do i find the right swaybar?
Old 01-03-2004, 02:54 AM
Drag-On's Avatar
Default How do i find the right swaybar?
can anybody tell me how to find out the right size for the swaybars?
There are such big differences between brands.
itīs for a daily driven, weekend auto-x EG6.
Thanks
Old 01-03-2004, 03:04 AM
eg6sir-s's Avatar
Default Re: How do i find the right swaybar? (Drag-On)
go with the beaks itr rear sway bar.
Old 01-03-2004, 03:07 AM
rjardy's Avatar
Default Re: How do i find the right swaybar? (eg6si)
will it bolt right up to a 6 gen?
Rob
Old 01-03-2004, 03:10 AM
Drag-On's Avatar
how much does it cost? where can i get it? which size is it?
Old 01-03-2004, 08:51 AM
Drag-On's Avatar
bump
Old 01-03-2004, 09:00 AM
6SPD_EK's Avatar
you need a ITR rear sway bar (22mm) & the beaks kit (you'll need the beaks kit to keep your subframe from tearing out). get them at http://www.beaksproducts.com get it all for about $250.00 or look in the classifieds - they pop up every so often. I got mine there for $200.00. you could have found that out if you searched
you might want a oem SI front sway bar (26mm) to complement the rear bar - if not could have some serious oversteer. you can get them from http://www.importautosalvage.com
lastly for autoXing I would suggest a Limitied Slip Differential (quaife is the best IMO http://www.quaife.co.uk lifetime warranty) to prevent excess wheelspin when cornering hard
edit - sorry i was thinkin this was for a 96+ civic me & listen to him below me
Old 01-03-2004, 09:01 AM
Solbros Owns Me
Evs-One's Avatar
I'm assuming ou're talking about the 92 Del Sol??
Don't listen to that guy ^
First off...what spring rates are you running, what tire size, what front sway, etc.'
For a daily driver/ autox car, a GSR sway will be plenty for a driver like yourself. I doubt you want to spend 1/2 your runs hittin cones sideways because your tail whips around when you let off the throttle
Old 01-03-2004, 09:22 AM
Drag-On's Avatar
Default Re: How do i find the right swaybar? (Emerika)
no, the bars should be for an EG6, which iīll get soon...
i canīt tell you the spring rates. all i know is that the car already has adjustable KW coilovers...
tire size is 205/50 15" Bridgestone S-03.
do the EG6 have a factory front sway?
Old 01-03-2004, 10:10 AM
Solbros Owns Me
Evs-One's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag-On &raquo;</TD></TR><TR><TD CLASS="quote">no, the bars should be for an EG6, which iÂīll get soon...
i canÂīt tell you the spring rates. all i know is that the car already has adjustable KW coilovers...
do the EG6 have a factory front sway?</TD></TR></TABLE>
yeah they do, I believe 21 or 22mm...I'm not familiar with your specs in Germany.
If it's a real EG6, I believe it should have a rear sway stock...but then again, I don't know my JDM
Old 01-03-2004, 10:18 AM
Drag-On's Avatar
itīs a real eg6. i know it has a factory rear sway, but itīs quite small, 14mm i believe...
Old 01-03-2004, 10:22 AM
Solbros Owns Me
Evs-One's Avatar
Get the car and see how it feels.
If you're running a stunna JDM coilover setup, I would suggest a bigger rear sway.
But if you're like us US guys, we run stiffer springs in the rear, and the need for a huge rear sway does not exist
Old 01-03-2004, 10:26 AM
Drag-On's Avatar
ok, thanks.
iīll ask again when i have the car
Old 01-13-2004, 08:05 AM
jr_istheman's Avatar
I've got a GSR rear swaybar for sale for 60$ shipped if you're interested. comes with everything: bushings, d-brackets, endlinks. most ITR bars out there don't include the hardware and you need to buy it seperately from Acura.
Old 01-13-2004, 09:02 AM
slammed_93_hatch's Avatar
really is no right size, some people will disagree and say "bigger is better", but it comes down to what you like as a driver, what makes you feel most comfertable. I run a 19mm when i bought it every one said "thats to small" and bla bla bla bla bla. I like it and i think if i went any bigger my *** end would kick out like a MO FLICKA. but this is my setup and what works for me
Got Utensils
Suspension & Brakes
10-08-2007 11:06 PM
JMD
01-26-2004 07:34 PM
mingchi69
10-07-2003 12:40 PM
RS_POWER
06-05-2002 06:09 AM
mamaboy
12-05-2001 09:07 PM
Quick Reply: How do i find the right swaybar?
