How can i Make my Cluster Light up AMBER?
is there a way where i can Make my Stock 95 civic hatch Cluster Light up AMBER?
is there something i can Buy or anything else i can get to make it Be AMBER?
if so pleast let me know
-thnxs
-thnxs
Re: How can i Make my Cluster Light up AMBER?
you have to take your whole gauge cluster out the replace each light bulb with an amber one. Or they also sell amber 'condom' you place over the light bulb. There is an old write up on here. Try searching for it
Def search man I've seen a bunch of these threads in the past. Another method is using a special spray that coats your bulbs with amber
Go to autozone or o'reillys and tell them that you need to know what type of bulb goes in your gauge cluster...then tell them that you want amber. they should be the same number but end in an A or something like that. You will have to take out your gauge cluster to replace each one of them. It's easy tho. I did it on my 93 EJ1. They're a couple bucks for a pack of them. My gauge cluster had like 8 of them i believe. I would recommend getting the amber colored bulb as opposed to the spray or the slips. Eventually the color will wear down but it always seemed to me like the color from the slips wear down sooner. Plus they're cheap enough. I also kno the trick for getting the clock on the dash to light up amber without buying a JDM one...and it only costs a couple bucks...but it's a secret. I had to figure it out on my own. Good luck
i used an orange sharpie lol works great did it to my climate control too take the bulbs out of the back and take the blue condoms off might be stuck on from so long just scrape them off with a razor blade clean them up and start coloring them with the sharpie
What you will need is 2 #74 and 5 #24 amber bulbs. You can get them from autoilluminations.com. I picked up a set of red and amber and personally like the reds more. I tried autozone, but they didn't have them in colored versions.
if you have ANY auto parts stores they will have the bulbs either use the amber bulbs or use an orange sharpie on the clear ones. they match my jdm clock perfect...
"longshot" did a write up on it..
he also made his Climate control light up amber
you can use an orange sharpie on the bulbs
and you can get a orange binder divider and made your clock amber also!
Wow...I'm glad that I'm not the only one that uses a binder divider for the clock...It's about time i hear someone say that they use it to make the clock light up amber.
you have to take the clock apart right? in order to put the divider in the back?
well, let me know!
i finish my cluster last night and it turnd out pretty nice! i want more of a red to it! but then i got it to light up so its okay
well, let me know!
